Looking for Short Course wheel recommendations for racing >
Old 06-22-2018, 06:32 AM
Bri
Default Looking for Short Course wheel recommendations for racing
What's your go to wheel for 1/10 Short Course racing? I'm currently using DE Trinidads but was wondering if anyone has found anything better.
Best regards,
Brian
Bri is offline
Old 06-22-2018, 06:49 AM
type of track / dirt and kind of dirt .
is track watered... and how often.
temperature.
size of track.
Truck/car being used
motor used.
skill level of driver.
in door or outside.
it matters.
rears I run AKA Enduro3..
loose sandy. large track. 17,5 motor. SC5M truck, skilled. outdoor. 75 to 95 degrees. intermittent sun and shade from trees.
chuck_thehammer is online now
Old 06-22-2018, 09:19 AM
kevinatfms's Avatar
DE Trinidad is my go to wheel but I also like the Jconcepts Rulux wheels since they are so cheap(Slash offset is $2 a pair).
kevinatfms is offline
Old 06-22-2018, 09:51 AM
DE Trinidad is the best wheel I've used. JConcepts Hazards are my 2nd choice
MaX-D is offline
Old 06-22-2018, 10:43 AM
azdakota97's Avatar
I run Avid's Sabertooth wheels because they are really light and strong. But I run 2wd 17.5 SC and wheel weight is very critical.
azdakota97 is offline
Old 06-22-2018, 11:46 AM
Not a fan of anything with thin spokes especially on a 4WD, for example just had one such wheel die on me as all the spokes snapped. Although in fairness it did last for a good 60-70 packs, the Blockades that were on them were just starting to bald out.
I like the ol' KMC hex wheels on my SC10/SC5M, unbreakable pretty much. Too wide rules-wise for racing with the SCTE, though.
tvih is offline
Old 06-22-2018, 11:58 AM
deleted.
Old 06-24-2018, 11:01 AM
bubbaslash's Avatar
AKA Cyclones
bubbaslash is offline
Old 06-24-2018, 11:50 AM
the rc guy's Avatar
all depends of what the surface is and how much grip you have and how that stays thru the race day or night. tri dots are my start tires on sticky watered clay.i like the drit I get in corners and the sure grip in straight or whoops.
the rc guy is offline
Old 06-24-2018, 02:18 PM
mkl
The DE Borrego wheels are good. If you are running 4WD I would also suggest to convert to 17mm hex's. The Borrego 17mm hex wheel is strong and stiff and never strip a wheel hex. it is not scale with spokes, but I don't care about that.
mkl is offline
Old 06-25-2018, 01:13 AM
I for one would love 17mm hex on my SCT even if just to get cheaper practise tires (1/8 buggy tires). But even if I still could find a conversion, all of them seem to make the SCTE too wide, enough so that the wheels would rub/hit the body edges.
tvih is offline
Old 06-26-2018, 08:37 PM
ta_man's Avatar
Trader Rating: 162 (100%+)
That seems to be the case with production parts. I made 17MM adapters for my SCTE from hubs designed for other cars and Ten-T axles. My 17MM hex is just barely wider than the 2.5MM cross-pin that holds the hub in place. I use the DE 17MM hub Trinidad SCT wheels. Because my hubs are so narrow, the wheels needed to clearanced to get full steering throw. The tires don't rub the body but it is still about 1/3 of an inch over ROAR legal width.
I have no problem doing this for myself but I can't imagine a manufacturer trying to sell a product and telling the user they need to modify their wheels for it to work.
I did this so I didn't ever have to worry about hexes stripping with the 12MM hubs. I've never tried to run 1/8th buggy wheels on the SCTE.
ta_man is offline
