Buggy Electronics help
Picked up a used buggy for my son with hobbywing esc and motor and savox servo. Am using an airtronics M11x and airtronics receiver. Went to drive today and its like the thing was glitching. It will drive for a second okay and then you don't have input to the servo or to the throttle so its impossible to race with and difficult to just drive with.
Any ideas? |
Which specific model number ESC and Savox servo? Some of the Savox servos draw a lot of amps so it's possible the ESC can't handle it.
Hw xe 150amp. The savox label is worn off
Try running a capacitor - theres cheaper ones if you dont go name brand
Glitch Buster Power Capacitor |
The servo is a 1268sg
Originally Posted by robl45
(Post 15246775)
Any ideas? |
(Post 15246906)
*NOTE: Certain combinations of receiver and ESC have been found to cause "Brown Out" issues when combined with Savox servos. An external BEC, or BEC stabilizing receiver capacitor may be needed for efficient, glitch free operation in low voltage electric applications. |
If the glitch buster doesn't help I would try to recalibrate the transmitter to the esc. If that doesn't work I would try a different radio.
And kind of off topic but did you ever figure out why your Outcast wasn't bottoming out? |
Tires too big on the outcast I suppose.
I tried cap today. Was a little better for a bit and then glitching . I suppose I need external bec |
Make sure the steering is smooth and moves freely with the servo disconnected. Also, make sure the end points are set correctly. A servo trying to push the steering beyond the stops will cause a high current draw on the bec.
The thing is it did this even with the servo horn off so its not just a potential binding issue. I just tried with an external BEC. One that I have used for years on my old Losi LST2 electric conversion. Still same issue. I can move the steering quickly and watch the receiver LED drop out. I'm out of ideas.
Get rid of that servo. Sounds like something is wrong with it. If it is so abused that the label is worn off you can bet that servo has had a hard life.
Seems like you need to change either the ESC or the servo to something either side can handle. The servo will likely be the cheaper option.
I wish I had a spare servo to test. Still this is a nice servo . I'm thinking maybe it's the radio itself? I may try to swap in receiver to the outcast and try that radio to see if there is any issue with that one.
(Post 15247334)
