Like Tree102Likes
Mugen MBX8 Eco
Old 12-23-2021, 07:26 AM
  #391
Now that the new nitro buggy is out, does anybody know when the Electric version should come out?
Numberonetrader is offline
Old 01-19-2022, 10:03 PM
  #392
Anyone running a shorty pack? Which body are you running? I think the proline one won't work but has anyone tried other ones? Drake runs J concept I think. I'd like to try a bitty design vision but not sure if it will clear.
srobert910 is offline
Old 02-09-2022, 03:48 PM
  #393
For those of you that changed the rear blocks and arms over to the 8R stuff on the MBX8Eco’s. How was your ride height on the rear? With my spring collars all the way up, the lowest I can get the rear is 29mm.
boatcapt is offline
Old 02-09-2022, 05:29 PM
  #394
Found out, you need to trim the shock ends 3mm if running the upper hole on the rear hub.
boatcapt is offline
Old 02-28-2022, 08:50 PM
  #395
tboned_2002's Avatar
Or you could could drop to lower hinge pin hole on the hubs
tboned_2002 is offline
Old 02-28-2022, 08:57 PM
  #396
Running Shortys w/ JConcepts S15 body, car is hooked up on the new 8R additions, however they come at a cost
Old 03-04-2022, 03:59 AM
  #397
Well. They presented the 8R eco.
Same as the nitro but could also run shorty packs. I also see a new cover for the center diff. More ventilated or just to be able to get stones out that get into there.
Jurassic579 is offline
Old 03-04-2022, 07:21 AM
  #398
Trader Rating: 31 (97%+)
Is there sufficient clearance between battery and body? More than with stock body?
perez62682 is offline
  #399
What is that little part behind the motor in the release photos? cant figure it out.
Old 03-04-2022, 07:53 AM
  #400
Fan mount?
Old 03-04-2022, 08:21 AM
  #401
New Mugen MBX8R Eco.
https://www.redrc.net/2022/03/mugen-...p-1-8th-buggy/
FolioHattu is offline
Old 03-04-2022, 09:39 AM
  #402
Fan mount?
good call. Still hard to tell, funky shape for a fan mount.
Old 03-07-2022, 12:18 AM
  #403
morgoth's Avatar
Not sure what is is. Maybe something to attach the sensor cable to so it doesn't flex too much and keep it from breaking?
morgoth is offline
Old 03-09-2022, 06:28 AM
  #404
Fan mount?
From the look on the exploded view on mugenracing.com its a fan mount.
F1nalized is offline
Old 03-14-2022, 09:21 AM
  #405
Tech Legend
Cain's Avatar
Trader Rating: 292 (100%+)
curious when the release date is for the R variant
Cain is offline
