Mugen MBX8 Eco
#331
What batteries does everyone plan to run this 2020 season?
#332
#333
Protek 5600 LIHV
#334
speaking of batteries does anyone notice the dwindled supply of 4s and 2s batteries on Amain ? ... I wonder if this has to do with the stuff happening over in china.
#335
Separate topic -- What bodys are most of you running, or is anyone spacing the body mounts up at all? I have a Bittydesign that is rubbing the 5mm posts on my battery. Running a Reedy Zapper 5200 with the posts vertical. If I rotate 90* the body contacts the whole battery
#336
Having an issue with handling that reared it's ugly head a while back. I'm running on an indoor medium to loose grip track. A lot of the time off throttle mid-corner to exit the rear end will spin out. I didn't use to do that until about 3 or 4 races ago. I made a few changes and it got a little better. I'm thinking next step may be to bring rear link into middle hole on hub. Thoughts? I've attached my set-up. Thanks!
#337
Sorry, but I can’t see that setup sheet very clearly. Can you make a digital one and post that one?
Also, you’re telling it’s on corner exit but offpower. Is that correct? I think I’m always on power when exiting a corner.
#338
off throttle. I'm thinking I need to move rear link to middle hole on hub, but haven't made it back to track yet to try.
#339
I have attached a digital setup copy. It was loosing rear traction in mid corner off throttle and then as exiting corner on throttle it would sometimes spin out. Most of the exit issues on throttle is ok with recent adjustments but still has tendency to spin out/loose traction mid corner
Also use the stock 9.0 front springs.
If you have issues mid corner, raising the rear diff fluid will help a lot. And a bit thicker front diff oil will also make it easier to drive.
I'd try 7 front, 5 center and 4 in the rear.
#340
Are you running 1.3mm holes in the front? 1.2mm gives a bit less front grip and makes the easier. If you keep 1.3mm, go up on front shock oil.
I'll also try diff oil changes. Thanks!
#341
Anyone know if you can use bladders in the m2c shock caps? Thanx
#342
Is there any other insert that works on part number Muge2134 besides Muge2119-B...they are stupid expensive for what they are. Will any other brand work?
#344
STUPID question here
Just picked up an older MBX8E. Can I use the WORLDS EDITION conversion kit for it? The gearing does that mess anything up on the E side of things?
Forgive my ignorance LOL
Mugen part# M1213 for reference
#345
I saw Drakes video on his MBX8E setup. He said he runs the Tekkno "Tracktion Drive" system on his. Looking at the video, it looks like he had to turn around his center diff to allow the system to fit on the motor and engage the spur. Has anyone run the "Tracktion Drive" on their MBX8E and if so did you have to flip you center diff (and if you did, was it necessary to cut a second hole in your chassis to provide room for the spur gear, it looks like if I flip the diff, the spur will drag on the chassis).
If anyone tried this, did you like the results driving/racing it over a standard pinion?
