Old 02-12-2006, 07:48 PM   #1
mattxxx-nt's Avatar
Default HAS THIS HAPPENED TO U
i was oud driving my xxx nt sport today. when i started it, it backfired like mad!!!
all the flames were 3 inches or longer. what does this mean???
TEAM HYBRID RACING
HPI SAVAGE 25
HPI SAVAGE 25
TEAM LOSI XXX-NT
OFNA MBX
mattxxx-nt is offline   Reply With Quote
Old 02-12-2006, 09:48 PM   #2
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
The engine is either too rich, your trying to start a hydrolocked engine, or there is insane blow-by.
Remove the glow plug after cleaning the area around the hole, and tip the car (Which has no fuel in it's tank) upsidown to drain the fuel from the crankcase. re install the glow plug and try again. If the problem persists, lean out the high speed needle about 1/8th of a turn and try again. If none of these things happen come back here and we can figure out a better solution.
Good luck!
Platinum_Racing is offline   Reply With Quote
Old 02-13-2006, 06:56 AM   #3
http://www.rchobbies.org/cars_eng-tuning.htm
http://www.rchobbies.org/engine-tuning.htm
these might help for what platinum said
mgtman is offline   Reply With Quote
Old 02-13-2006, 10:32 AM   #4
How can I get my car to backfire like that? That would be killer!!!!!!
1fsttraxxas is offline   Reply With Quote
Old 02-14-2006, 12:32 PM   #5
mattxxx-nt's Avatar
i re tuned it and it still bach fifes and it wont start any more
TEAM HYBRID RACING
HPI SAVAGE 25
HPI SAVAGE 25
TEAM LOSI XXX-NT
OFNA MBX
Old 02-14-2006, 02:12 PM   #6
what kind of fuel are you using? 101 octane?
ALJR is offline   Reply With Quote
Old 02-14-2006, 03:03 PM   #7
Crim3Wav3's Avatar
DUDE...these engines DONT shoot flames out of ANYWHERE! are you making this up or what????
Crim3Wav3 is offline   Reply With Quote
Old 02-14-2006, 04:40 PM   #8
SpeedBump57's Avatar
I would think an ill running engine with alot of blow bye could do some thing like that. I have seen engines backfire and then run backwards, very strange site to see.
SpeedBump57 is offline   Reply With Quote
Old 02-14-2006, 07:26 PM   #9
GregH's Avatar
Send a message via AIM to GregH
try a fresh glowplug.....
I've started my engine before and it started run backwards. I just bump it once on the box and it's running right again.
GregH is offline   Reply With Quote
Old 02-14-2006, 07:37 PM   #10
WheelNut's Avatar
Send a message via MSN to WheelNut
Yeah dude are you even running nitro in the thing?
WheelNut is offline   Reply With Quote
Old 02-14-2006, 08:28 PM   #11
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Lets think how an engine works, backfire is from fire in the cylinder when the exhaust opens up with an over kill in fuel. 2 cycle engine with a backfire is bad. I would assume the rod or rod bearing is damaged not letting the piston travel upward enough to seal off the exhaust port and the the fire is bleeding by the piston out the exhaust. Or some how your jug has turned, head loose, and the timing is out of wack between the intake and exhaust. Anyway, I wouldnt try to start it again till the engine is torn down and inspected, if you backfire into the crankcase and out the carb, the front seal or the crankcase will be damaged.
PS make sure if you are using a roto start or start box that the battery is plugged in correctly. I have started my savage backwards when my boy reversed the polarity on my roto start. It is scary and freaky.
JPMSRacing is offline   Reply With Quote
Old 02-14-2006, 09:31 PM   #12
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Alcohol flames are not visible to the naked eye......
...Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 02-14-2006, 11:24 PM   #13
Trader Rating: 22 (100%+)
Send a message via AIM to 5thscaleracer
it is possible for the exhaust tho throw down some flames, blue flame not your typicall yellow.
It has happend to me at one time working for a hobby shop. Customers Crappy car Duratrax Street Force of CRAP had a hard time starting, i check all the standard stuff, needles, fuel clog, bad glow plug etc etc...
every thing checked out good started to tug on the Crap Starter engine pop and i didn't think much of it. I pull again Engine starts back fires, flames on the glass counter then motor stalls. I stear at the flames for a good 20 seconds trying to figure out if it's even possible. put out the blue fire and try it again. poof 2 times in a row!
tried for the thrid time and nothing i was able to tune the motor and the customer is on his way but that was the first time i saw a back fire and flame form a nitro engine.
there is always a first for every thing!!!
5thscaleracer is offline   Reply With Quote
Old 02-15-2006, 04:35 AM   #14
Suspended
Default It means your truck is gonna be really really fast!
its so fast its shooting flames sitting still!
Jhyten is offline   Reply With Quote
Old 02-15-2006, 05:30 AM   #15
This is why RTR's are killing this HOBBY!!!!!!!!!! You should have proper knowledge of how to tune and operate a nitro engine before you even pull the cord!!!!!! I've raced for 18 years, and only 3 out of the last 18 have been with any sort of nitro car. I spent many hours learning to tune motors, research each powerplant, and then testing them. Every summer, I'll attempt to help new drivers with their cars and how to operate them, however, if you cannot find help at a track, or at a hobbyshop with TRAINED pro's, give up on the nitro thing before you get yourself hurt!!!!!!
bshack is offline   Reply With Quote
what the [email protected]!! happened slowpokeRRR Micro and Mini Scales 4 01-28-2007 07:44 PM
What happened to? Schuie Driver Electric Off-Road 2 03-26-2006 06:31 PM
Has this ever happened to anyone? sho .21 Monster Trucks 8 03-19-2006 03:25 PM
how come this happened? VenomWorldOrder Australian Racing 11 10-18-2004 03:42 AM
OK, what happened? Speedo R/C Tech Site Forum 45 09-04-2001 07:18 PM
