Team Associated T6.1 >
Like Tree119Likes
Old 05-22-2018, 01:13 PM
  #61
Trader Rating: 161 (100%+)
Originally Posted by sea1swk View Post
My local track believes they will have one for me Thursday (5/24). I like to start with a setup sheet, from a Pro running a similar track? I don't see any, anywhere? Do we know what is needed when purchasing? We race 13.5. Different Spur?
Go to petitrc and look at the pictures of Brent Thelke's truck from TRCR. Its all there in pictures what he ran.
jpcopeland1 is offline
Old 05-22-2018, 02:59 PM
  #62
Just happened to go to Tower today and saw the T6.1 was available, so I bought one. Never finished my B6D that I bought a couple of months ago and now I have another project. Sweet!!
StadiumRC is offline
Old 05-22-2018, 04:31 PM
  #63
I preordered in April from AMain...just got the email that it has shipped!!!!
Big_Show likes this.
skidooboy84 is offline
Old 05-23-2018, 01:53 AM
  #64
Watch out in the manual, it says the stroke of the shocks should be 21 front, 28 rear. That is very wrong. Those are for the buggy. Try and thread the end all the way like that, and you'll punch through it. It has to be at least 27 front and 35 rear.
Old 05-23-2018, 06:14 AM
  #65
Trader Rating: 28 (100%+)
AE has some different set ups posted now.
bobf24 is offline
Old 05-23-2018, 11:36 AM
  #66
sea1swk's Avatar
AE has the Manual posted now. I picked up last night from TRCR. Started building. Good so far.
sea1swk is offline
Old 05-23-2018, 07:37 PM
  #67
tibbs's Avatar
Trader Rating: 12 (93%+)
Anybody know if they are going to have a sway bar kit for this?
tibbs is offline
Old 05-23-2018, 09:13 PM
  #68
malcnz's Avatar
manuel quotes b 6.1 sway bar kit
malcnz is offline
Old 05-24-2018, 08:34 AM
  #69
Default Lay Back to Lay Down
Originally Posted by Jon Carlson View Post
Yes, the case and the laydown idler gear.
I run on carpet / astro so looking to switch to the laydown trans with a gear diff.
I'm looking at the 6.1 Gearbox Configuration chart and I see that I need the 91716 - B6 Idler Gear and the 91791 B6.1 Laydown Gearbox, but I don't see where it says what gears I need to go in the laydown case. Does anyone have this listed out?
Cfleek is offline
Old 05-24-2018, 08:52 AM
  #70
Krio's Avatar
Trader Rating: 155 (99%+)
Everything else you need is included in the kit. The top shaft, idler gear shaft, and differential are the same. All you need is the larger idler gear 91791, laydown gearbox, and the gear differential if you don't want to use the included ball diff.
Jon Carlson likes this.
Krio is offline
Old 05-24-2018, 08:55 AM
  #71
The gear differential is where I'm stuck / confused. Is there a kit I need to buy with all the right parts? or do I need to piece this together using the B6 as a guide?
Cfleek is offline
  #72
Big_Show's Avatar
the top shaft from your layback transmission will fit the laydown. So you should just need the laydown case and B6 idler (39 tooth) gear to make the switch which you have the part #. Plus the gear diff. If you want to have both transmissions built and ready then you would need this top shaft 91799 also.
Big_Show is offline
Old 05-24-2018, 09:06 AM
  #73
I'm told Part# ASC91786
Team Associated B6.1/B6.1D Gear Differential Kit is the correct kit for anyone looking. I'll have mine tomorrow so I'll know for sure! Thanks, everyone!
Cfleek is offline
Old 05-24-2018, 09:29 AM
  #74
yes, same gear diff kit from the buggy, all of the transmission parts for the trucks are identical to the buggy,
bobf24 is offline
Old 05-24-2018, 09:44 AM
  #75
E-Mann's Avatar
Trader Rating: 36 (100%+)
Does anyone have a link to the correct gear differential kit I need? I thought I found it, but it's discontinued.
ASC91786 is the complete 6.1 gear differential
Cfleek likes this.
E-Mann is offline
