Team Associated T6.1 >
Like Tree119Likes
Old 04-30-2018, 06:11 PM
  #46
Big_Show's Avatar
On my Exotek T6 I am able to mount the shocks on the front using the Jconcepts Finnisher T5M body. Have to use the shortest bolts and the B6 aluminium shock mounts. Leave the tower on the back side of the transmission and space things out right and the shocks will not bind.
Big_Show is offline
Old 05-09-2018, 09:53 PM
  #47
Big_Show's Avatar
AE put some the of the T6.1 parts up today. I am only waiting on the chassis, rear A arms, 91mm dog bones, and body mounts and I will have everything to build a T6.1 using a T5M body. Have layback and 3 gear stand up ready and waiting.
Gigasipke likes this.
Big_Show is offline
Old 05-10-2018, 04:06 AM
  #48
mes
Ruddog received the T6.1 body yesterday, so I reckon the kits are not that far off.
Jon Carlson and Big_Show like this.
mes is offline
Old 05-14-2018, 08:03 PM
  #49
Big_Show's Avatar
The T6.1 chassis, dog bones, and body mounts put up today. Will have them Thursday. Only thing I am waiting on now are rear A arms. Have the front end of the truck together and waiting on the chassis. I will assemble the T6.1 with T5M rear A arms until the 6.1 A arms are up. Building it with the 3 gear stand up as it is out door season and I am running on non sugured loose tracks. Loving the Exorek conversion with the 4 gear, so I have a 4 gear built for the 5.1 also. Have my B6.1 fairly hooked up with the 3 gear stand up, so I have hope the T6.1 will work well with it also.
Big_Show is offline
Old 05-14-2018, 11:00 PM
  #50
Trader Rating: 31 (100%+)
I drove one on carpet last Saturday. It's pretty fun. So much easier to drive than a 2wd buggy ....not as agile though.
Big_Show likes this.
Phillip F is offline
Old 05-15-2018, 05:23 AM
  #51
Trader Rating: 28 (100%+)
So just to verify all we need to get the standup going is the case, motor plate, top shaft and idler? and hopefully the gear cover comes with the truck like it did the buggy.
Jon Carlson likes this.
bobf24 is offline
Old 05-15-2018, 07:26 AM
  #52
Krio's Avatar
Trader Rating: 155 (99%+)
Yes, minus the idler. The layback uses the same idler as the standup. Only the laydown is different.
Krio is offline
Old 05-15-2018, 02:31 PM
  #53
fullsyzz's Avatar
Trader Rating: 110 (100%+)
Pre-order now available: #70002 (RC10T6.1 TEAM KIT)
T
TeamAssociated.com <[email protected]>
Yesterday, 11:37 AM
You
Hello,
On Mon, April 2nd, 2018 you requested to be put on a waitlist at TeamAssociated.com for part #70002 (RC10T6.1 TEAM KIT). We now have some good news; your wait is over!
Due to high demand, we have reserved you one of these items. You have until Wed, May 16th, 2018 at 6:36pm PST to complete your purchase on this item, otherwise it will be offered to the next person on the wait list.
fullsyzz is offline
Old 05-16-2018, 09:34 PM
  #54
malcnz's Avatar
do you know what had been changed to make it carpet ready? as surface i will be running on.
malcnz is offline
Old 05-20-2018, 04:54 AM
  #55
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I would look at the differences in the B6.1 and B6.1D. Sway bars, springs, steering bushings, laydown transmission case, gear diff. Those items should get you very close.
Jon Carlson is offline
Old 05-22-2018, 12:52 AM
  #56
malcnz's Avatar
cheers..for sure..let hope after this weekended Brent might post what changes he made on its debut race...i have a gear diff to put in and thinking maybe harder springs....do you know what is involved in making layback into laydown apart from the casing? cheers.
malcnz is offline
Old 05-22-2018, 04:23 AM
  #57
Regional Moderator
Yes, the case and the laydown idler gear.
Old 05-22-2018, 09:36 AM
  #58
sea1swk's Avatar
My local track believes they will have one for me Thursday (5/24). I like to start with a setup sheet, from a Pro running a similar track? I don't see any, anywhere? Do we know what is needed when purchasing? We race 13.5. Different Spur?
sea1swk is offline
Old 05-22-2018, 11:54 AM
  #59
Looks like they have arrived to some tracks already. Seen them posted on FB
youngrigo is offline
Old 05-22-2018, 01:12 PM
  #60
Trader Rating: 161 (100%+)
Losi Pars House has them as well, picking mine up as we speak.
jpcopeland1 is offline
