Team Associated T6.1 >
Like Tree161Likes
Old 07-18-2019, 11:46 AM
  #481
my rear shocks are mounted the standard way in the kit, not the optional mount where they go on the INSIDE of the tower/car
any feedback as to why shocks on the inside of the tower are better than outside? still havent ran this truck yet will be going to the track this weekend its a carpet track btw
vegas7o2 is offline
Old 07-18-2019, 06:35 PM
  #482
Inside of the shock tower has helped on carpet. Rear mount is typically used to add grip on a low grip surface
a1 likes this.
Blarson1 is offline
Old 07-22-2019, 03:58 PM
  #483
Trader Rating: 166 (100%+)
Originally Posted by slakr View Post
For the gear diff build, you can use the B6.1 manual... https://img2.associatedelectrics.com...B6.1-90020.pdf
For diff oil, depending on motor, track surface and grip, will dictate how thick. Higher motor wind (like 17.5 stock racing) = lower viscosity diff oil. Less traction (loose dirt) also = lower viscosity. Lower motor wind (like 6.5 mod motor) = higher viscosity, and likewise more traction (carpet) = higher viscosity. I would say overall range is probably 3000 to 15000... https://www.amainhobbies.com/team-as...453215?v=18319
depends also on track size and how much “ drive” forward you want the truck to have. Too thick and it will overdrive the front adversely effecting steering. Trucks with gear diffs in general do need thicker oil. My truck has 2 gear 10k setup for it, and it’s money on a smallish high bite carpet track.
jpcopeland1 is offline
Old 07-22-2019, 04:09 PM
  #484
Originally Posted by fastev View Post
Interesting to hear about the JCon bodies. I wonder if there was a bad batch. There were 3 guys at my track whose bodies all fell apart very quickly. Two of them split from wheel well to wheel well through the body post holes and the front fell off. These were excellent drivers, I know crashing wasn't the issue. Third wasn't quite as extreme, but it was the first track day using it and the rear post holes blew out leaving a huge hole.
I stand corrected on these and will revise my comment.
everything about the F2 is bad lol....
  #485
sounds good thanks!
vegas7o2 is offline
Old 07-28-2019, 04:16 AM
  #486
Originally Posted by Krio View Post
The plastic steering rack and front hinge pin mount are about the only things I've consistently seen upgraded on the T6.1 for durability.
This is totally the truth. I didn't finish a single qualifier yesterday due to these parts
zmlnr8 is offline
Old 08-03-2019, 03:44 PM
  #487
so do you recommend aluminum rack ? what brand?
any chance you can link or list part #s
vegas7o2 is offline
Old 08-03-2019, 06:15 PM
  #488
Trader Rating: 21 (100%+)
The more grip you race on the more your steering needs to be aluminum. My outdoor cars are all stock. My carpet ones run all aluminum.
Mxfrodo195 is offline
Old 08-18-2019, 03:52 PM
  #489
i understand the t6.1 team kit comes with "layback"
I was told laydown is ideal for carpet.
https://www.amainhobbies.com/team-as...c91791/p742858
is this part here what I need to switch to laydown? Is there anything else required to do this besides this part or do i need to buy a diff gera setup or something
vegas7o2 is offline
Old 08-20-2019, 02:11 PM
  #490
Greetings all. Purchased a B6.1D yesterday. Should arrive in a day or two. Been out of the hobby for about 25 years. The most modern of my 5 cars and trucks is a Losi XX. Actually my RC10 GT could be a little newer. Sorry if this is the wrong place to post but I looked for a "introduce yourself" type thread and couldn't find one. Cheers
Milkdudd is offline
Old 08-20-2019, 02:17 PM
  #491
Sorry just realized this is T6.1 thread. What a great first post huh?
Gayosaka and 3TurnRacing like this.
Milkdudd is offline
Old 08-21-2019, 04:51 AM
  #492
You also need the larger idler gear (91716), everything else crosses over between the two.
If running on high bite you would be advised to go for a gear diff as the ball diff, although ok in a buggy, can't really handle the extra torque loading from the larger truck tires on surfaces like carpet and astro.
RogerM is offline
Old 08-21-2019, 07:18 AM
  #493
I got the gear diff installed already , so just buy that laydown enclosure and a diff idler gear and it's good to go?
I'll have to buy the same for the buggy next
vegas7o2 is offline
Old 08-21-2019, 08:05 AM
  #494
Yes. Here is a link that you might find particularly useful.
https://img2.associatedelectrics.com...ns-04-2019.pdf
To be honest, layback vs laydown is not going to make a difference in your case. Having the right tires, a decent setup and practice will mean a lot more.
071crazy is offline
Old 08-21-2019, 09:48 PM
  #495
great, sorry if this sounds stupid first question after opening that is how do I know if i have a 3 gear or 4 gear? I would think 4 gear based on whats in the diff (gear) however thats probably not what they are referring to and Im confused.
thanks in advance
vegas7o2 is offline
