Team Associated T6.1 >
Like Tree161Likes
Old 04-11-2019, 10:19 AM
  #436
Thanks. Didn't think about doing a quick recalibration. I'll try that as well.
ouhockeyplayer is offline
Old 04-11-2019, 11:18 AM
  #437
Originally Posted by Krio View Post
The plastic steering rack and front hinge pin mount are about the only things I've consistently seen upgraded on the T6.1 for durability.
Thanks for the info!
Relaxin is offline
Old 04-13-2019, 05:48 AM
  #438
Trader Rating: 360 (99%+)
...sorry wrong thread
jonski is offline
Old 04-19-2019, 11:10 PM
  #439
Default Need advice
I want to get an electric stadium truck to practice and improve my driving skills.
locally we do not race 1/10th scale but from my understanding if you are able to go fast with a 2wd vehicle you will be fast with a 4wd.
I know nothing of 2wd trukt so I need some advice what are the recommendations for this car and i'm thinking of getting something used as this is a practice car.
any advice on equipment will be great as I am planning to use this car on a 1/8 scale track
moisesing is offline
Old 04-20-2019, 06:40 AM
  #440
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I never want to talk you out of getting a T6.1 but, if you don’t race them, and it’s meant for a 1/8 track... I don’t want you to resent getting it either. The best practice is going to be with the car you want to be good at. Look for different lines, try driving slower and not needing any marshals, then add the speed back. Things like that. Good luck, feel free to ask if you have other questions.
a1 likes this.
Jon Carlson is offline
Old 04-26-2019, 08:20 AM
  #441
Reno's Avatar
Trader Rating: 18 (100%+)
Here are my thoughts....
I race 1/10 ST, 2wd buggy, 4wd buggy, 1/8 truggy, 1/8 buggy. The 1/10 we race on carpet. Now that hones your skills!
I don't think a 1/10 ST on an 1/8 scale dirt track is going to accomplish what you want. The best thing to do is just take the 1/8 and practice as much as you can. Buy a used 1/8 for practice and run the heck out of it.
Reno is offline
Old 05-03-2019, 09:36 PM
  #442
Trader Rating: 44 (100%+)
Kind of slow around here.. Long live 2WD ST.. Here's a race of mine from last weekend.
Bartman42 is online now
Old 05-31-2019, 10:49 PM
  #443
Trader Rating: 19 (100%+)
Finishing up a build for 17.5. What are some running weights people are seeing? Only set up I could find was at about 1850 grams. Ready to run and without a body my truck is at 1771 grams. That's with the brass c mount and aluminum electronics plate. Thanks in advance for any help.
Chris Brown is offline
Old 06-01-2019, 03:22 AM
  #444
mes
Comparing apples to oranges here, but my YZ-2T was below 1700 with 20g of sticky weights in front of a full-size Futaba servo, with a small Muchmore Euro V2 esc, gear diff, Schelle slipper, Lunsford turnbuckles and the painted kit body. Oh, I almost forgot I am using the very light Performa Racing 4000 mAh batteries, which shave a lot of weight (weighing ~125 g).
mes is offline
Old 06-25-2019, 08:40 PM
  #445
Just picked up a T6.1 roller. what size pinion is recommended for kit 81T Spur. with 17.5 Motor. Layback config.
was thinking of dropping down to 24/78.
thanks!
bostoneric is offline
Old 06-25-2019, 09:19 PM
  #446
Big_Show's Avatar
On clay I was running 27/78 with a fan, coming off at 130 degrees on a 7min main.
Big_Show is offline
Old 06-26-2019, 05:56 AM
  #447
Di_spencer's Avatar
thanks!
I ran my t6.1 at stock nats at OCRC and I ran 25/78 with a 30mm R1 thick fan finished 4th in the 10min A main and motor came off at 130. Plenty of punch and speed.
Di_spencer is offline
Old 06-26-2019, 06:36 AM
  #448
What motor were you running?
Old 06-26-2019, 06:44 AM
  #449
Di_spencer's Avatar
Oh sorry. Tekin 17.5 spec R with titanium timing screws and about 35-40 deg of endbell timing
Old 06-26-2019, 11:13 AM
  #450
what size battery were you running?
