Team Associated T6.1
#376
I'm running the 13.5 spec-r with 50* timing on motor analyzer, geared 81-20. After 6 minute main it's 135* with R1 layback fan and mount.
#377
81/22 for small tracks where you need full throttle control, 23 for most tracks, and 24 for high speed/8th scale style tracks works perfect for the spec r
#378
Quality, 13.5 blinky and running on carpet
Hi all,
I was just wondering the following regarding this truck:
1. I am only running on outdoor carpet tracks.
2. What upgrades are required for running 13.5 blinky?
3. What is the quality of the kit like, do items wear out?
Thanks.
Thanks.
#379
The body included is very thin and wears out quickly without reinforcement, the replacement body is thicker as well as the jconcepts one.
2. Look at the Kody Numendhal carpet setup for a good setup that details the upgrades. Gear diff, aluminium bell cranks, brass bulkhead, chassis weight and servo weight would be my first go to upgrades for carpet.
3. Aside from the body the kit is good quality The ballcups can wear and begin pop off so I’d get spares of those or use the B5m ones if you can find any (discontinued). The arms, hubs and caster blocks all wear eventually.
#380
#381
Yeah all the bodies are shit for it . They all need to have the rear shock part thicker. They all break.
#382
I'm continually not impressed with Jconcepts stuff. Plus, their shipping prices are astronomical.
That said, if you order a replacement AE body from Amain it is much thicker than the kit body. I've got about 6 months on mine on indoor carpet and it's shot, but it lasted much longer than the kit body.
Just throwing this out there... I'd been running my rear shocks on the from of the arms. I just moved them to the back of the arms in an attempt to make the truck a bit more forgiving. I'm going to try a T5, or dare I say it, an Xray body to see how it fits. In my opinion, the Xray bodies are hands down the best looking, which is a plus if they fit.
#383
my gear diff nylon gear is worn out in my t5m , this items seems to be discontinued by associated. Do you know if the 6.1 diff will fit?
#384
the thinner associated body did me good and lasted me a while. When It was finally unusable I ordered the concepts one and it seem pretty heavy duty and I was impressed . Until it fell apart in pieces within two battery packs. Temps were 60 degrees out so dont know how much a factor that was but the associated body last me a good while longer that the concepts body. The concepts body broke apart in pieces. Yes the track is brutal but on the same track the associated lasted longer, I guess because it was more flexible
#387
#388
I bought one of these used and need to buy a new body. Is it definitive that they all suck and are paper thin? Or is there one body that's thicker than the rest?
#389
I've yet to see a JCon body last more than a few club race nights before becoming unusable-- on either the T6.1 or the Yokomo truck.
#390
my jconcepts body has lasted me 3 or 4 months with barely a crack on it. and I crash a lot. the body that comes in the kit I wouldn't even bother painting. so thin it will be destroyed the first day. theres about 20 guys running the jconcepts body at my track with no issues. I highly recommend it.
