Team Associated T6.1
#271
I guess ive done somethig wrong. I have the flat of the screw flush and with nut tightened down the screw is just flush with top of nut. Also not comfortable with the small nut. Having to grab another tool where i didnt before. Going to try and put some 5m thumb screws.
#272
there has to be something off... the nuts have never backed off of mine, it's a non issue. The nuts use the same wrench as the wheel nuts... that should always be out on a pit table
#273
They use the nut they do because it carried over from the buggy set up where the side rails are much narrower and there isn't enough room for a bigger nut without getting into the body, On the truck you can for sure use a thumb nut, I actually used the old ones off my T5m for a while, but its not going to change the number of threads available.
#275
#277
I don't think this is the place to ask that question, you would probably have a better chance of getting an answer in the general issue thread
https://www.rctech.net/forum/r-c-tech-site-forum-14/
#279
Kit Turnbuckles
How are the steel kit turnbuckles? I used to always replace my kit turnbuckles with Lunsford titanium units, but I thought I might just stick with the kit parts this time to save myself a little time and money. Any comments are appreciated. Thanks.
#282
I'm trying to get my T6.1 going and was wondering if I could get some electronics advice? This is the first kit I have ever built. Im running a Hobbywing XR10 Pro ESC and a Sanwa MT-S radio system. When attempting to break the diff in I noticed that changing the throttle trim does nothing. Steering trim and sub trim work as expected. I used the setup wizard on the radio and set it up as a EP standard car. ESC is plugged into channel 2 and steering into channel 1.
#283
#284
Yep, ESC was calibrated after the setup wizard and binding was complete. I believe Hobbywing said to hold down the power button to put it in calibration mode. With the throttle at neutral push the power button. Then do the same for full brake and full throttle.
#285
Are you just asking why the throttle trim doesn't do anything or is something in the ESC not working correctly?
I'm not familiar with that radio set up but if its just the trim doesn't do anything it might just be the radio turns that function off since you put it in EP mode and throttle trim isn't something you should be adjusting on an electric car since you should just calibrate the ESC. Switch it to nitro mode and see if it works then.
