Schumacher's NEW Cat L1 4wd Buggy! >
Like Tree161Likes
Old 07-11-2019, 09:33 AM
  #391
jag5508's Avatar
Trader Rating: 15 (100%+)
Any good setups for high bite carpet that anyone is running in 13.5? Right now my car absolutely sucks.
jag5508 is offline
Old 07-21-2019, 08:03 AM
  #392
jag5508's Avatar
I guess not time to switch brands .
jag5508 is offline
Old 07-21-2019, 08:32 AM
  #393
Did you find something that works? I use the setups right off of Schumacher's website.
scoobyrs25 is offline
Old 07-21-2019, 10:58 AM
  #394
jag5508's Avatar
No I didn't . I'm pretty much all set with this car theres always something with it . i'm going to switch to something else soon .
jag5508 is offline
Old 07-23-2019, 07:24 PM
  #395
mickrcarver's Avatar
Trader Rating: 98 (98%+)
Default New l1
What pinion for a small/med small jump clay track, will be running 6.5 t
mickrcarver is offline
Old 07-23-2019, 07:25 PM
  #396
Oh and do i need a special long pinion???
Old 07-23-2019, 10:01 PM
  #397
I run around 18 teeth and yes you do.
Old 07-24-2019, 05:29 AM
  #398
Ok thanks
Old 07-24-2019, 06:40 PM
  #399
Reflexia's Avatar
You can get by without a long boss pinion in the short term. Long term get your self a Corally Long Boss.
Reflexia is offline
Old 09-11-2019, 06:21 PM
  #400
Hi all,
Just putting my new L1 together. Having issues mounting the gear/bearing in step 10. Every time I tighten the screw up the gear becomes stiff and rough, not free spinning and smooth, not sure why it is doing it.
I have checked, double-checked and triple-checked I am following exactly what the instructions are saying.
Also, I have read that the 3 gears should have plenty of grease on them, which the book doesn't say. What type of grease and where?
gumby1987 is offline
Old 09-11-2019, 06:57 PM
  #401
The manual always leaves out thread lock on all aluminum parts too.
Old 09-11-2019, 07:05 PM
  #402
Yep, aware of that one.
Old 09-12-2019, 07:29 PM
  #403
How do these cars go in dirt?
Do you find the belts get clogged easily?
EGG ROLL is offline
