Schumacher's NEW Cat L1 4wd Buggy! >
Like Tree161Likes
Old 03-23-2018, 06:17 AM
  #16
Blurb says 3 gear transmission for opposite motor rotation but doesn't it just end up rotating the same way it would if the spur was on the pulley shaft? I assume given the diffs are small and the pulleys relatively large the 3 gears are to get the internal ratio in a good range?
Is there going to be an option to use different gears there to change internal ratio for restricted motor classes? Also any plans for plastic gears for diff internals? I saw alloy shafts listed in option parts but not lighter gears.
Marman is offline
Old 03-23-2018, 06:35 AM
  #17
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Yes side gears are for reduction. I’ll check into stock gearing and report back.
We are testing plastic internal diff gears now. All goes well I will post link to availability etc
rippen and sgtlt like this.
Tony Newland is offline
Old 03-23-2018, 06:57 AM
  #18
Internal ratio is 2.45:1. Similar to others. We also have 69/72/76 lockout spurs as well as selection of slipper spurs. Spec racing shouldn’t be a problem
Old 03-23-2018, 07:22 AM
  #19
Car looks great!
Rhett McNair is offline
Old 03-23-2018, 10:43 AM
  #20
Opposite to K2...
AntH3000 is offline
Old 03-24-2018, 06:10 PM
  #21
Does anyone have a list of the option parts from the K2 that still will work?
For example:
- The Alloy Yokes have a different part number, but will the old work?
- Rear Hubs I'm assuming still work even though new part number?
- No change the front Tower mount is the same as the new rear tower mount?
- The arms are different, but will the old ones fit?
Anyway just curious if anyone has a list? Just like to know what I'd need to keep and what I can get rid of !
matt_ is offline
Old 03-26-2018, 10:21 PM
  #22
Trader Rating: 45 (100%+)
Wow healthy price tag $549.00 pre order @ AMain. I hope that changes a little bit cuz this is one sexy buggy. A lot of new designing went into this 4WD buggy. How has the testing been going Tony Newland?
edit..price got changed today 3/26/18 that's a whole lot better!!
Tanis103 likes this.
Propchecku37 is offline
Old 03-27-2018, 07:55 AM
  #23
Tanis103's Avatar
Originally Posted by Cain View Post
be curious on seeing the electronics layout for a shorty.
Cain, rippen, losicorey and 2 others like this.
Tanis103 is offline
Old 03-27-2018, 09:57 AM
  #24
Default drc
Originally Posted by Propchecku37 View Post
Wow healthy price tag $680.00 pre order @ AMain. I hope that changes a little bit cuz this is one sexy buggy. A lot of new designing went into this 4WD buggy. How has the testing been going Tony Newland?
Check dRC! Better deals
MelKF2 is offline
Old 03-27-2018, 10:42 AM
  #25
that’s a sweet layout pic
Thanks MelKF2 I will look into dRC
Old 03-27-2018, 10:43 AM
  #26
Originally Posted by Tanis103 View Post
Any room for a motor cooling fan
Old 03-27-2018, 11:28 AM
  #27
KOULLIT's Avatar
Hi,
Is Schumacher the first manufacturer to use a center pivot for this type of ackerman design ?
I don't remember, but it seems they are the first to use it.
We know that the older system was non symmetric, with different steering results between right and left wheel, but many other brands told me it is insignificant...
It seems that Schumacher prefer this design now !
I will continue to monitor this on other brands futur models...
Bye !
KOULLIT is offline
Old 03-27-2018, 02:11 PM
  #28
The belts seem to be made out of a different material. I wonder if they cause less friction and are more durable than the old belts.
°°.°°ABMC°°.°° is offline
Old 03-27-2018, 03:36 PM
  #29
vikingen's Avatar
Trader Rating: 28 (100%+)
slightly off topic, but any idea what Orlowski will do in regards to running gear gear / LRP ?
vikingen is offline
Old 03-27-2018, 05:47 PM
  #30
I think I read the belts are a polyurethane drive belt.
