Hobbywing QuicRun QR10BL120 for stock racing?
I’m sure it’s been asked a lot but is the Hobbywing QuicRun QR10BL120 esc suitable for stock class racing I just recently bought a 17.5 motor and plan on putting it in my b6d.
It will work, but I would just buy a hobbywing justock for 50 bucks. It’s made specifically for stock racing and is rock solid
Yeah, since stock drivers generally want minimum weight, the XR10 Justock is 40g lighter than the 10BL120, and you don't need 120A with a 17.5t motor.
You can set the timing to 0, but I don't think there is a blinky light, so that may cause problems if your club cares.
Ok thanks I’ll get one ordered
I totally agree with everyone else as the hobbywing juststock is great. If you want to splurge a little the XR10 pro stock v4 is 119.99 (amain pricing) and even smaller and lighter being roughly 20-30 grams lighter (according to amain).
ROAR Racing
Our club will spec every car before the mains.
Hello, can we use motor with timing like Rocket 540 V5R in Quicrun BL120? do I need to set the motor timing to 0?
Just make sure you are not adding lots of static timing in the ESC settings and with the motor endbell at the same time.
I run my quicrun 120 at zero timing.
I run my quicrun 120 at zero timing and then have timing on the motor.
Answered in the other thread where you posted the same question...
As far as the motor's end bell timing goes, that's fair game and can be adjusted to suit your needs for a given track layout.
