Traxxas Rustler VXL sand tires
Need some help? I ordered some 2.8 sand tires and wheels that they offer from Traxxas and they are huge, installed they look ridiculous but states on the package there for the Rustler, want some good sand tires for front and rear but clueless what size to order?
2.2" is standard for ST's, this is the size tire I would get:
https://www.prolineracing.com/tires/...ck-rear-tires/
while that might make sense for all manufacturers to use the same offset, Traxxas uses their own proprietary offset so you just need to select 2.2" wheels that are labeled to be compatible with the Rustler, here is an example:
https://www.amainhobbies.com/jconcep...o3336b/p198876
*** It won't do you any good to know what the offset is anyway because wheels are not sold by that metric, only by proprietary compatibility.
Take a look at the HPI sand thrower 2.2 sand paddles . Ive had a set for 4-5 years and use them every time I go to the dunes they work really well especially with the front sand runners . I have them mounted on RPM Revolver wheels which you can get in the correct offset . it looks pretty bad a$$
