Will TLR 22 4.0 rear buggy arms fit on 3.0 buggy? >
Old 03-11-2018, 12:19 AM
Default Will TLR 22 4.0 rear buggy arms fit on 3.0 buggy?
Looking to fit the shocks onto the inside of the rear suspension arms of a 22 3.0 buggy, will 4.0 arms fit with little modification? Thanks
Joosh M is offline
Old 03-11-2018, 09:09 AM
Arms fit straight on but you wonít be able to mount the shocks on front without a laydown conversion in the car.
losi8lunie is offline
Old 03-11-2018, 11:19 AM
Thanks for the info, I already have the shocks mounted on the front of the 3.0 arms. I had to drill the holes and I was just wondering if it would be easier to just get the 4.0 arms when they break.
Joosh M is offline
Old 03-11-2018, 12:33 PM
K_King's Avatar
Trader Rating: 47 (100%+)
They will fit
K_King is offline
Old 03-11-2018, 12:37 PM
Trader Rating: 14 (100%+)
Good to know. My sons 3.0 arms already have mounting holes in both sides of the rear arms. Since I can’t seem to find anymore lay down trans set ups moving the rear shocks forward will help I’m sure on the clay tracks we will run.
Rlmxracer is offline
Old 03-11-2018, 12:53 PM
Edit, the shock doesn’t quite line up. Oh well, not much waisted.
Old 03-11-2018, 01:35 PM
Originally Posted by Rlmxracer View Post
Edit, the shock doesnít quite line up. Oh well, not much waisted.
You canít use the original stand ups to run shocks on front - you need to replace with a bolt and some washers. See Ellis car picture in the link below
http://site.petitrc.com/setup/losi/setuptwentytwo3.0/223.0_EllisStafford_MuelheimKaerlich2016012931/
