Like Tree1Likes
Traxxas Titan 12t
Old 03-05-2018, 08:08 AM
  #16
Trader Rating: 228 (100%+)
Originally Posted by ls1velle View Post
It has an 86/19 ratio right now. What do you guys run?
I use a 83/17 on a 110' banked clay oval and motor temp is 150'ish.
Andy Koback is offline
Old 03-05-2018, 11:41 AM
  #17
Bri
I would try removing the pinion gear and then spin the rear wheels. The rear wheels should spin fairly free (not as free as the front wheels). If you notice a fair amount of resistance, then you most likely need to change out a few of the bearings. If all seems well, then a going down a tooth on the pinion gear should do the trick.
Best regards,
Brian
BRS Hobbies
Bri is offline
