Team Associated B6.1 & B6.1D thread >
Like Tree1089Likes
    Hide Wikipost
Old 03-24-2020, 06:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday and Roger M.):
Print Wikipost
Old 02-22-2018, 05:41 AM
  #121
Trader Rating: 28 (100%+)
If you are looking at the "d" versions I personally dont think there will be a huge performance difference going to the new one. You should be able to find a nice used one with the 67mm bones and everything at a good price once the new ones are out that would get you most of the way to the new buggy.
I think you can put the new arms on the old buggy so the only thing you are really missing is easy diff access and possibly the "layback" transmission if that worked at your track, but even then for the tracks I run on I think I would need the old style stand up anyway.
bobf24 is offline
Old 02-22-2018, 06:41 AM
  #122
mes
IMHO the new chassis will make a difference on all types of surface, but I guess only time will tell...
Chris Reilly and Big_Show like this.
mes is offline
Old 02-22-2018, 10:03 AM
  #123
Just get the new car and then you won't have to update. AE released the new car because it is better or they would never do it.
55Guy likes this.
Chris Reilly is offline
Old 02-22-2018, 10:18 AM
  #124
55Guy's Avatar
Trader Rating: 104 (100%+)
I would strongly consider going with the newest model of whatever version fits your needs would be the best option. Cost could be a factor in one's decision but you will have parts and support available longer. Besides in a couple of years or less it will be the old model anyway.
55Guy is offline
Old 02-22-2018, 11:59 AM
  #125
Trader Rating: 32 (100%+)
The shorter chassis is the best part of the new car imo. The b6 drives way better with the shorter chassis and it comes on the new car. To be perfectly candid, not too many of us can drive a b6 to its full potential, so can we just say that we all want the new car cause we gotta fit in in the cool guy club.
Normajean and 55Guy like this.
Skeeter36 is offline
Old 02-22-2018, 12:14 PM
  #126
Suspended
Everyone gets something different out of the hobby. I like that manufacturers are trying to make a faster race car. It means the 1/10th scale buggy segment (my favorite btw) of the hobby is doing well. The more people out racing, the more manufacturers will make cool new stuff. It doesn't matter if you want the new car to try to go faster, or because you enjoy building a new car. As long as you are having fun.
People like to complain too. Hard core racers will question design choices, others might say the release is too soon or unjustified.
I think AE has done a good job on the B6.1's. I'm excited to see how the car does when it is released.
urnotevenwrg2 is offline
Old 02-22-2018, 01:48 PM
  #127
Default Parts are listed!
https://www.teamassociated.com/cars_...s_accessories/
mes and Ross71 like this.
AE_Stig is offline
Old 02-22-2018, 02:11 PM
  #128
Originally Posted by sacmiata
I dont think I would say its the consensus but a lot of people here already have the b6 and are looking at the upgrade in a positive light. So if you don't have a b6 I say its worth the wait and extra money to be at the forefront of buggy development. For me I am likely going to sell my car (with Kashima's and a few other goodies) for 200 and would happily spend the difference for the upgrade.
If this is a new class to you I would just get a b6 and save the money....especially with the used/lightly used prices being so tempting. I think the b6 will still remain competitive for a while especially in the sportsman.
This is a great response... Thanks.
The difference between the two kits here in Australia, just checking now, is as little as $50... After reading your reply it's a no brainier to go the 6.1D...thanks again!
Yess is offline
Old 02-22-2018, 02:42 PM
  #129
Krio's Avatar
Trader Rating: 159 (99%+)
The current gen 4 gear transmission and motor plate are listed... Hmm. Gives me hope that the bolt pattern is the same and I can drop the layback into my B6d with minor mods.
Krio is offline
Old 02-22-2018, 06:33 PM
  #130
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
You know we want more than that right. We are never satisfied.
Kraig is offline
Old 02-22-2018, 10:34 PM
  #131
Super Moderator
b1narych0ice's Avatar
I was figuring there would be some sort of two piece top shaft... are those roll pins?
b1narych0ice is offline
Old 02-23-2018, 01:26 AM
  #132
5tone's Avatar
thank's for the link !
is the B6 gear diff fit in the B6.1 gearbox ?
5tone is offline
Old 02-23-2018, 02:10 AM
  #133
lexusbest's Avatar
Yes, it does. B5 diff does too with the correct spacers. So many changes in that gearbox Im thinking how the f* could I make it fit into the current B6
lexusbest is offline
Old 02-23-2018, 05:04 AM
  #134
its kind of nice they narrowed the gear on the top shaft for the direct drive kit, nice touch,
bobf24 is offline
Old 02-23-2018, 05:36 AM
  #135
Mason's Avatar
don't fret, i'm sure somebody will have an all titanium option soon.
Mason is offline
