Team Associated B6.1 & B6.1D thread
#901
#903
Phillip, gather your gears and send them into AE. You and the guys who experienced this represent what they would likely consider an extraordinary failure rate. I bet they'll want to check those parts out.
#904
Maybe the gear cases are a factor. I noticed I had to loosen and tighten it a couple times to get everything to line up before I put it in the car. It's only molded plastic. A friend of mine put an aftermarket laydown in his kyosho a couple of years ago and he kept blowing idler gears because the case was a little off.
#905
What’s this car coming it at for weight in box stock 17.5 form? (Light motor, stock esc etc).
#907
You ran direct drive in a very high bite situation with a 13.5 and more than one of you all had the same result....... Don't get mad because I'm right.
#908
I don't believe you're right. He and his buddies wasted almost as many idler gears in a race day as I've seen go in 30 years of racing (we didn't always have slipper clutches, either), running in rather unremarkable circumstances. A 13.5 just doesn't make gear shredding torque.
Phillip, also check the machining of the lay shaft gear, check for sharp edges on the tooth profile?
#909
I used a fan mount from rc speed secrets. I drilled the hole out for the rear side guard and installed a longer screw. Then secured it with a nylock nut. No body clearance issues. Obviously this only works the the Associated lockout installed. I don't know if you could move it around to work with a slipper, but I wanted to share this with others trying to mount a fan.
I'll post some pics when I get a chance.
#910
But they do. I shredded plastic diff gears in a b64 on astro paired with a 13.5. But on dirt they are fine. The ultra high bite surfaces we are running today are a lot different than anything in the past. Were the gears I was using defective...no. Was I using them in a situation that I shouldn’t have, yes. My bet is the direct drive in that situation...especially since it repeated itself multiple times. There is zero benefit to using a direct drive in that situation.
#911
The power of the motor is not what is causing the problem. If you are running pin tires on carpet (basically 0 slip), something has to give. Even with a 17.5, when the throttle is applied in the air and the car lands, the rotation momentum of the drive train must be absorbed. Without a slipper or tires/racing surface that gives during landing, the next weakest link will fail and in this case, that appears to be the idler gear.
#912
4 different guys in one day? Just seems like too many to me.
I agree about the slipper. I run one in all situations.
#913
While it may have been ok (doubt it) in 17.5 it definitely wasn't in 13.5.
#914
Still not buying it...
#915
what is there to buy?! You agreed about the slipper. You said you’d always run one. The issue here is a direct drive coupled with pin tires on high grip carpet. Something has to give. I give up.
Run whatever you want but don’t complain when you ruin stuff and blame the manufacturer. It’s definitely no your fault....
