Team Associated B6.1 & B6.1D thread >
Like Tree793Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 04-19-2018, 07:27 AM
  #811
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 167 (100%+)
Originally Posted by skrib21 View Post
What is everyone doing to get the Jconcepts S2 B6 bodies to fit with the layback tranny? It Looks like I need to cut a big portion of the gear area out to get it to fit but that will completely expose the spur gear to debris.
just trim slowly...it doesn’t take a lot but you can easily go overboard.
Matt Trimmings is offline
Old 04-19-2018, 07:46 AM
  #812
B6.1 build tips video I found, for any that are interested.
gswart44 is offline
Old 04-19-2018, 09:19 AM
  #813
I had to cut a silly amount for it to fit the lay down...
buggybattle is offline
Old 04-19-2018, 03:07 PM
  #814
Test
Fastenal Guy is offline
Old 04-19-2018, 03:23 PM
  #815
B6.1d arriving in a couple days. Have 2 choices for electronics.
a) 510r/8.0 m3 Reedy/1206 servo
b) rs gen 2/gen3 8.5/T130 servo.
Not sure what to build with. One set will go back in my Sc5m. Until I can rob another bank and get the sc6.
Any thoughts? Thx.
Old 04-19-2018, 05:28 PM
  #816
510R combo
Chris Reilly is offline
Old 04-20-2018, 03:13 AM
  #817
Braxamus's Avatar
Got my kit last night Mr UPS finally showed up, and started the build got it about 80% done. I am going to run 17.5 stock with it, but I am not going to go crazy on the gearing, timing and only charge my batteries as recommended I do not over charge like some do I want my stuff to last. Since the kit came with only one spur gear and I have to buy one what should I get the manual recommends a 72 but I have seen where some recommend a 69-70 I race at The Ohio RC Factory and EN Hobbies (old Sparks Park) in Ohio if anyone has been there and knows a good start point I'd appreciate the info. So far I really like the kit been flawless going together so far, that whole lay back trans and rear shock tower setup is built like a brick and is very solid IMO.
Braxamus is offline
Old 04-20-2018, 05:42 AM
  #818
Trader Rating: 40 (100%+)
I remember reading that the Direct drive kit could use The old school Kimbrough spur gears. They do fit the gear hub, but you cant tighten the nut against the gear because of the big hole in the gear. Am I missing something?
Scott R is offline
Old 04-20-2018, 05:55 AM
  #819
The nut holds the aluminum plate the gear bolts to onto the shaft, it's not designed to hold the gear on.
Tijuana_Taxi is offline
Old 04-20-2018, 07:18 AM
  #820
TC5Driven's Avatar
Get a 69 spur gear and 30 tooth pinion. You can use a pinion from 29 to 31 tooth depending on layout. This is good for 17.5 motor
TC5Driven is offline
Old 04-20-2018, 07:23 AM
  #821
I understand what you're saying but you're misunderstanding. I'll take a photo of it tonight to help explain.
Scott R is offline
Old 04-20-2018, 07:25 AM
  #822
I made a quick chart with all the New V2 and V1 spring rates for comparison
File Type: pdf
Still Bill, mrniss99 and mett1971 like this.
Scott R is offline
Old 04-20-2018, 08:09 AM
  #823
BRSracing's Avatar
Trader Rating: 63 (100%+)
Gearing depends heavily on the motor, and the version of the motor. Don't take any advise on gearing unless the person you are getting it from knows what motor you are running.
BRSracing is offline
Old 04-20-2018, 08:20 AM
  #824
Trader Rating: 20 (100%+)
Is there a difference in internal gearing compared to the B6? The 72t spur being included vs the 69 is a bit strange. Unless they are gearing it (no pun intended) toward the new motors that like to rev a lot.
MX304 is offline
Old 04-20-2018, 08:21 AM
  #825
Still Bill's Avatar
Trader Rating: 15 (100%+)
Thanks Scott.
Scott R likes this.
Still Bill is offline
