Team Associated B6.1 & B6.1D thread >
Like Tree588Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 04-16-2018, 12:03 AM
  #751
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Originally Posted by leskai View Post
Anyone have an updated parts list to convert a b6 into a b6.1? I have seen a pic of someone putting together one but no part numbers and i don't think its adequate or complete. Trying to compare pricing between buying the required parts for the conversion or just a whole new kit. I saw that there won't be a conversion kit sold as well.
91765 chassis, 91772 c mount, 91775 rear mount, 91791 laydown, 91795 motor plate , 91769 rear tower, 91813 gear cover, 91792 diff height insert , 91800 direct drive or 91801 slipper spring, 91803 inner hub, 91804 outer hub, 91799 top shaft, 91779 v2 rear hub, 91763 67mm cvd kit, 91820, 91821, 91822, 91823 front and rear sway bars, 320, 316 button head screws, 2 of 36, and 1 of 2.58 flat, etc...
Phat-Boy is offline
Old 04-16-2018, 02:02 AM
  #752
Thanks for this! Quick question can you use the rear tower from the b6 or are the holes different? I thought the difference was the thickness.
leskai is offline
Old 04-16-2018, 04:34 AM
  #753
Braxamus's Avatar
Originally Posted by urnotevenwrg2 View Post
The kit is in a way larger box than the electronics?
LOL yea that's it.
Braxamus is offline
Old 04-16-2018, 06:29 AM
  #754
kiwi_tim's Avatar
Trader Rating: 17 (100%+)
Ran my D kit setup on outdoor dirt yesterday ( flipout/holeshot track) , had a brass D and 43g
Under lipo weight.
Didn't do too bad, have v2 green springs and brass C coming, Interested to see if anyone else has had luck with the lay back on proper dirt.
kiwi_tim is offline
Old 04-16-2018, 06:51 AM
  #755
Phat-Boy's Avatar
B6.1 tower is around 1mm shorter and bottom wholes are narrower according to guy who wrote earlier. I haven't compare mine. You can use it with little modification and adjust ride height I guess.
Phat-Boy is offline
Old 04-16-2018, 08:10 AM
  #756
TC5Driven's Avatar
Well my son placed "first in the stock A Main" yesterday at OCRC raceway in Huntington Beach. He ran the B6.1D with the layback transmission and everything was "box stock". He ran the new Tekin Redline Gen 3 17.5 with a Just Stock Hobby Wing ESC. His starting position in the A Main was 12th after bumping up from the B Main. Here is a copy of the race link from Live RC. OCRC Raceway :: Sunday Series Round 2 :: Team Hitman's Buggy A-Main :: LiveRC
socalcloin likes this.
TC5Driven is offline
Old 04-16-2018, 08:59 AM
  #757
What are the bearings (part 31400) for, I still had these left over when I finished the kit? Also are people using the wing mount spacer?
EDIT: I see they are for ball diff
NitroHippo is offline
Old 04-16-2018, 10:05 AM
  #758
Wow...awesome man! Great success for him personally, and the B6.1 platform in general. And cool to hear that it was with the layback gearbox. I'll be running my B6.1D on high-bite indoor dirt, and was wondering if I should order the laydown gearbox and idler, but hearing good early success stories with the layback, like your son's makes me think I should give the kit setup a good shot first.
Thanks for posting man, and very cool A main win with the new car for your son!
TC5Driven likes this.
gswart44 is offline
Old 04-16-2018, 10:53 AM
  #759
Phat-Boy's Avatar
I'm using spacer it should give more traction on rear but I can't feel difference...
Phat-Boy is offline
Old 04-16-2018, 04:44 PM
  #760
Trader Rating: 15 (100%+)
Will the B6D Schelle rear alum hubs work on the B6.1?
bladeys is offline
Old 04-16-2018, 05:12 PM
  #761
Phat-Boy's Avatar
yes. Make sure you have white insert on rear of hub for 67mm axles.
Phat-Boy is offline
Old 04-16-2018, 06:49 PM
  #762
Suspended
Have you ever raced rc cars before? If so how long ago? Because if you are brand new, you are worrying way too much about things that will have zero impact on your ability to get your B6.1D around the track. A stock B6.1D will in no way hold you back, you need to drive it the way it is, and learn to drive.
If you are not new, and just coming back from a long break there is no way you will feel held back by a box stock B6.1D either. When you can run .5 of a second off of your fastest lap for an entire race with a box stock, kit setup B6.1D, then you can make adjustments and start with the aftermarket upgrades. Build the kit perfectly, put the right tires on it for your track, and give it a shot. I guarantee your driving will hold back your stock B6.1D, not the other way around.
urnotevenwrg2 is offline
Old 04-16-2018, 06:59 PM
  #763
Phat-Boy's Avatar
Need some reviews on B6.1D!
Phat-Boy is offline
Old 04-16-2018, 07:01 PM
  #764
fast-ho-cars's Avatar
when i read that it was going to have a shorter chassis than the B6 series, i was expecting something like they did in the past where they did 4-7mil or more lengthening on the old B4 series to deal with bigger outdoor tracks. figured they would do something more noticeable when it was touted as being shorter, but do notice now many times it's no longer mentioned in features list as it was weeks back.
fast-ho-cars is offline
Old 04-16-2018, 07:07 PM
  #765
Trader Rating: 24 (100%+)
So the aluminum b6 hubs won't work on the 6.1D? I saw something about they need to be milled for clearence.
tallguy2 is offline
