Team Associated B6.1 & B6.1D thread >
Like Tree1049Likes
    Hide Wikipost
Old 03-24-2020, 06:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday and Roger M.):
Print Wikipost
Old 02-14-2018, 05:32 AM
  #61
FSimi's Avatar
Trader Rating: 16 (100%+)
I got a B6D for Christmas and I use it three times only and the B6.1 is already here. That is my destiny
FSimi is offline
Old 02-14-2018, 06:16 AM
  #62
olds45512's Avatar
Originally Posted by henry View Post
Hello. I am interested in purchasing the new B6.1d for the outdoor season this summer. The tracks I race on are loose (holeshots and 3ds are common). Would the stock three gear transmission work for tracks like this or would the original b6d four gear work? Thank you.
The b6d comes with a 3 gear stand up trans, if you want a 4 gear you need to buy a b5m. AE is going to have a 3 gear stand up for the 6.1d but you might be better off just buying a b6d for a loose track.
olds45512 is offline
Old 02-14-2018, 06:19 AM
  #63
Trader Rating: 28 (100%+)
they sell a 4 gear kit for the B6d as well so you don't need a b5m
bobf24 is offline
Old 02-14-2018, 06:31 AM
  #64
Need to figure out what extra parts to sell with my B6 and what to keep to use in the B6.1. Think the current B6 weight inserts(steel/aluminum) will work in the new B6.1 chassis or will we need to get new inserts?
Phugazi is offline
Old 02-14-2018, 06:46 AM
  #65
Nobody knows for sure, but in all likelihood, all the upgrades from the front of the car up to the gearbox will work for the new car. New chassis is a scammy way to deter people from doing conversions instead of buying a new car. Maybe scam is too harsh of a word but 3mm difference and a few new holes for the gearbox hardly justifies the cost in my opinion.
Fearo is offline
Old 02-14-2018, 07:04 AM
  #66
Trader Rating: 20 (100%+)
Shocks, pretty much the entire front clip and steering parts, rear tower, chassis weights (although it appears the 6.1 will come with the chassis weights in the box)
MX304 is offline
Old 02-14-2018, 07:29 AM
  #67
Default Diff Height/Gear Boxes
When the diff height is changed, the idler gear does not need to move. It is a true quick change diff height.
There are 3 new gear boxes for the b6.1 (3-gear stand up, Laydown, and Layback). All of them have a quick change diff and all of them allow the shocks to be ran on the front.
Scott R likes this.
AE_Stig is offline
Old 02-14-2018, 07:56 AM
  #68
looking to get a 2wd buggy to run and son wants associated should we go ahead on the 6.1d or get the old model ?
Jfowler is offline
Old 02-14-2018, 08:03 AM
  #69
Krio's Avatar
Trader Rating: 159 (99%+)
Depends on your budget. Personally, I'm setting up my daughter with a used B6d because for $200 less, she won't be able to tell the difference for a very long time. By then, the .2 will be out.
Krio is offline
Old 02-14-2018, 08:45 AM
  #70
What they are referring to is that the diff cannot merely move straight up or down. It will only be meshed perfectly at one location. Above or below that the diff has to move slightly forward as well to maintain proper gear mesh as it has to move along an arc from the center of the idler. Do the inserts have this feature built in?
fredswain is offline
Old 02-14-2018, 08:48 AM
  #71
I read they intentionally left this out of the inserts, that way people will strip out idler gears and have to buy extra parts.
Of course they accounted for it in the inserts!!!!
bobf24 is offline
Old 02-14-2018, 09:03 AM
  #72
Thats exactly what i ment!
micholix is offline
Old 02-14-2018, 09:06 AM
  #73
I know what they are referring to but if you place the idler gear in the center of the diff height range and then go 1.5mm up or down from there, the gear mesh changes by 0.05mm. Holding calipers up to the light at 0.05mm will show this is not an issue.
CedarCityJohnny and Scott R like this.
AE_Stig is offline
Old 02-14-2018, 09:57 AM
  #74
Kalio's Avatar
Does anyone know if there will be any kind of upgrade kit made available from the B6/B6D? Or does that seem pretty unlikely?
Kalio is offline
Old 02-14-2018, 10:12 AM
  #75
E-Mann's Avatar
Trader Rating: 36 (100%+)
Rivkin said in the JC video they will not have a conversion kit.
Just by looking at pictures I came up with the chart attached. As you can see full conversion is close to the 6.1 price. This is just for B6 not B6D.
E-Mann is offline
