Team Associated B6.1 & B6.1D thread >
Like Tree805Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 04-04-2019, 08:32 AM
  #2641
Trader Rating: 15 (100%+)
Anyone looking to sell a 3 gear stand up, tall tower & the ballstud mount, hit me up.
HeavyD99 is offline
Old 04-04-2019, 01:46 PM
  #2642
So.. Where are the parts? I'm looking for B6 front hubs, and they seem to be rarer than hens teeth.
Nerobro is offline
Old 04-04-2019, 01:57 PM
  #2643
Krio's Avatar
Trader Rating: 154 (99%+)
Not sure if you'd settle for a whole front end bundle of parts, but this is in stock:
https://www.amainhobbies.com/team-as...c91776/p742845
Krio is offline
Old 04-04-2019, 01:59 PM
  #2644
The 6.1 hubs are the same and sold as a whole set.
Here is the part number for the b6.1 parts ASC91776.
Di_spencer is offline
Old 04-04-2019, 05:31 PM
  #2645
Super08's Avatar
Correct, I don't think they sell the hubs by themselves anymore. It is cheap enough just to buy the tree with all the parts on it.
Super08 is offline
Old 04-04-2019, 07:21 PM
  #2646
My local hobbyshop probably has 4-5 packs of front caster blocks for the B6 last time I needed some.
Chris Reilly is offline
Old 04-05-2019, 02:27 AM
  #2647
Braxamus's Avatar
My LHS does not stock anything but Traxxas junk and thinks its the best in the world. he says he can order whatever I want but if I have to make 2 trips there and wait 3-4 day I might as well order online. The HS at the one track we race at does carry some parts that might be needed for quick fixes in case something breaks while racing which is nice, but some stuff you would still have to order.
Braxamus is offline
Old 04-06-2019, 11:38 PM
  #2648
RDucky47's Avatar
Protek 160ss servo. When mounting: servo spacers or no spacers? Thanks
RDucky47 is offline
Old 04-07-2019, 12:48 AM
  #2649
Trader Rating: 58 (100%+)
No spacers. If you put them in it will push the servo too far forward.
Prostreet314 is offline
Old 04-07-2019, 09:03 AM
  #2650
RDucky47's Avatar
Thank you
RDucky47 is offline
Old 04-07-2019, 12:07 PM
  #2651
Originally Posted by Super08 View Post
Also the 6.1D has the tall rear strut tower, longer rear shock bodies, and 7MM rear hexes. None of those make a big enough difference for what they cost imho.
Carajo is offline
Old 04-09-2019, 07:30 PM
  #2652
Originally Posted by Davidka View Post
FWIW, you might consider just doing the suspension updates and the ball diff. The lay-down transmission format is pretty popular with the dirt guys (it is the stock configuration in the FL kit, which is a dirt-stock racer). Unless your track is fairly low grip, I'd just stay with it.
thanks. To take it further if i wanted to convert to Factory Lite is ASC91844 $90 MIP system all I need?
dogbone418 is offline
Old 04-09-2019, 07:53 PM
  #2653
Davidka's Avatar
Trader Rating: 83 (100%+)
Yes, you could. I donít think itís worth the cost, though. The car runs great with the stock, steel driveline.
dogbone418 likes this.
Davidka is offline
Old 04-10-2019, 06:34 AM
  #2654
Super Moderator
Kraig's Avatar
Trader Rating: 78 (100%+)
If you want to use some of your existing parts I would agree with Davidka. However, if you want to build it and just drop it in you will need the following:
91419 Diff Gear
6575 Diff Thrust Bolt Parts
6581 Carbide Diff Balls
6582 Diff Spring
7666 Diff Drive Rings
31400 Bearings, 5x8x2.5 mm
You could buy 7677 Diff Rebuild Kit which would replace 7666, 6582, and 6575.
I think that is everything that is needed.
Kraig is offline
Old 04-10-2019, 07:03 AM
  #2655
Davidka's Avatar
I believe there are even a few NIP B6.1 diff kits in the for sale section on this forum, so you could get them for less that way.
Davidka is offline
