Team Associated B6.1 & B6.1D thread >
Like Tree805Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 02-22-2019, 01:14 AM
  #2461
For strictly stock 17.5 regular d or the lite? clay indoor in Mi Dirtburners and clubhouse?
outoftouchrc is offline
Old 02-22-2019, 03:42 AM
  #2462
Mr. Bubby's Avatar
Hey guys. Looking at either the B6.1 team kit or B6.1 Factory light. Will only be running on carpet tracks or combination carpet and turf. In your opinion which would be better to start off with. Since the Factory light comes with all the lightened goodies and I'll be running just stock, I'm thinking that this is the way to go. But from some people I've talked to, the lightened stuff just doesn't hold up as well on the Super Traction tracks. Any thoughts???
Mr. Bubby is offline
Old 02-22-2019, 06:47 AM
  #2463
Krio's Avatar
Trader Rating: 154 (99%+)
I would go with the Lite for 17.5 only at Dirtburners and Clubhouse, but it's a close call. The layback transmission with a slipper would probably be better at DB since the surface can be a bit choppy, but the laydown with the slipper eliminator would be ideal for Clubhouse.
Without buying extra parts, you should go with the B6.1. The aluminum bones and ball diff in the Factory Light will be a weak spot on carpet/turf, even with a 17.5 motor. Or you could get the FL and install a gear diff and steel driveshafts. You'll probably want the springs and weight plate that comes in the B6.1, though. It's a matter of deciding what parts you want in the end and which route is cheaper.
Krio is offline
Old 02-22-2019, 07:28 AM
  #2464
D1360's Avatar
What size arm reamers do you use on the B6/B6.1 ?
D1360 is offline
Old 02-22-2019, 09:51 AM
  #2465
Default thread pitch
It's been suggested to run a tap through some of the tight plastic peices. M3 diam, but what is the pitch .35 or .50?
mediumquick is offline
Old 02-22-2019, 10:14 AM
  #2466
Braxamus's Avatar
I have heard good and bad things about pre tapping stuff some say its nice for assembly but weakens it also.
Braxamus is offline
Old 02-22-2019, 10:21 AM
  #2467
Krio's Avatar
0.50 is what you want.
Krio is offline
Old 02-22-2019, 10:32 AM
  #2468
I have a gen 1 b6 with the 67mm puck system so basically the identical setup as on the b6.1 FL and I've been running it on a very high grip indoor clay (think damp track with slicks where there's so much grip when you get on the throttle the tires make a popping noise) for over a year with about one track day a week and the pucks have lasted me about 1-1.5 months before I replace the plastics and after about a year the bones had worn enough around the pins that I replaced them. Overall I think they have held up very well and they do make a BIG difference everywhere on the track. My vote goes to the FL.
Di_spencer is online now
Old 02-22-2019, 10:46 AM
  #2469
mes
The B6.1 team kit is a better package for carpet and astroturf. If you want to reduce rotating mass, I'd recommend the Schelle Nova slipper SCH1309, but I'd not go for a slipper eliminator or cut gearbox internals.
I found the only spot to watch was the point near the hinge pin screw. Use a 3 mm drill bit or maybe even a body reamer to remove some material after installing the screw and you should be good to go. An arm reamer won't do the trick because of the screw blocking the hole (as intended).
mes is offline
Old 02-22-2019, 11:23 AM
  #2470
No big deal just pick up the layback same motor plate and the I have the gear where I put the lay down in my t6 and sc6. Thanks.
Old 02-23-2019, 07:38 PM
  #2471
offroad dude's Avatar
Trader Rating: 30 (100%+)
Can someone tell me where I can buy some cut gears foe my stock 2wd?
offroad dude is offline
Old 02-24-2019, 12:27 AM
  #2472
Rc speed secrets has the gears for a reasonable price
Kelseyrc is offline
Old 02-24-2019, 01:11 AM
  #2473
Trader Rating: 58 (100%+)
​www.rcspeedsecrets.com is the place go for cut gears and other performance parts.
offroad dude likes this.
Prostreet314 is offline
Old 02-24-2019, 12:57 PM
  #2474
Besides the quick diff access, are the any differences between the b6.1 and the b6 suspension geometry? sorry for silly question.
trigger is offline
Old 02-24-2019, 02:21 PM
  #2475
Davidka's Avatar
Trader Rating: 83 (100%+)
The 6.1 has 67mm dog bones, which is an aftermarket update on the 6 and the chassis is a few mm’s shorter and the updated rear arms have more shock mounting options. The “d” version also has the shorter “layback” transmission and the longer rear shock bodies.
Davidka is offline
