Team Associated B6.1 & B6.1D thread >
Like Tree681Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 03-02-2018, 06:15 PM
  #211
Trader Rating: 31 (100%+)
Originally Posted by cameronspruill View Post
Will the new B6.1 laydown tranny work in the B6?
If you drill new holes in your B6 chassis... it will work
Phillip F is online now
Old 03-02-2018, 06:18 PM
  #212
cameronspruill's Avatar
Trader Rating: 21 (100%+)
Ahh ok so it takes serious altering to make it work
cameronspruill is offline
Old 03-02-2018, 09:30 PM
  #213
you are better off buying the B6.1 kit than converting your B6 to a B6.1
Old 03-04-2018, 02:40 AM
  #214
Has anyone a partslist when I want to start with the 3G for the B6.1D? Or is it just the Standup Gearbox and motor plate??
man1ac is online now
Old 03-04-2018, 09:20 AM
  #215
mes
AE have released a new parts list and it mentions a stand-up specific topshaft, too. To be sure, I'd wait for the manual hoping that they will include an exploded view of the optional gearboxes like TLR do.
New parts: https://www.teamassociated.com/pdf/c...rts-List-B.pdf
mes is online now
Old 03-04-2018, 04:32 PM
  #216
CrawJac's Avatar
Does anyone know if the B6.1D will have about the same weight as the B6 or the B6D? I'm curious to see how much weight difference the 3MM of chassis makes.
CrawJac is offline
Old 03-05-2018, 10:16 AM
  #217
Trader Rating: 23 (100%+)
Originally Posted by Jason B View Post
As a stock racer, I never needed a fan on either of my B6D's. My 22 4.0 on the other hand... saw motors go up, and almost lost one of my own, no matter the gearing.
Doesn't matter if it "goes up" or not - when magnets get hot, they get weak. You're talking the difference of a motor lasting a month or 6. Which would you rather have?
Coke in a can is offline
Old 03-05-2018, 12:04 PM
  #218
ray_munday's Avatar
The b6 chassis weighs around 130g, so taking 3mm off a 280mm long part is going to change only around 1.5-2g due to length alone. If they have changed thickness at all it will be a more significant change.
ray_munday is offline
Old 03-05-2018, 12:21 PM
  #219
Assume that I have a temp gun and know how to use it, and that the spirit of my post was simply that, in most cases, a properly-geared stock buggy does not need a fan. I called out the 22 4.0 because it is the exception, and me recounting the fact that I saw several of them "go up" when not running a fan was simply me speaking to how severe the problem is. I was NOT implying that you gauge motor health by whether or not it's on fire. I have no clue how you managed to infer that from my post.
Jason B is offline
Old 03-05-2018, 05:09 PM
  #220
damewood99's Avatar
Default pre order
where has everyone pre ordered the new car from?
damewood99 is offline
Old 03-05-2018, 05:57 PM
  #221
LHS
jiml likes this.
Rebuke is offline
Old 03-05-2018, 06:47 PM
  #222
Are the 6.1 buggies just hands down that much better than the 6? I know when I went from the 5m lite to the 6 I was so impressed how much easier the 6 was to drive compared to the 5m lite so is it gonna be that again?
Old 03-05-2018, 07:33 PM
  #223
Trader Rating: 14 (100%+)
Im not seeing a big performance gain, just some ease of maintenance. Could be wrong though, The layback is intriguing for a slow guy like me.
DG Designs is offline
Old 03-06-2018, 06:29 AM
  #224
davidfast's Avatar
Trader Rating: 24 (100%+)
We clearly won't know until we get our hands on them.....I would think it's safe to assume it will be better, by what factor of course will be determined by the skill of the driver
RogerM and cameronspruill like this.
davidfast is offline
Old 03-06-2018, 06:39 AM
  #225
Krio's Avatar
Trader Rating: 152 (99%+)
I think if you go from a bone stock B6 you will notice a big difference. If you already have the 67mm bones, did the 3rd hole on the rear arms, mod to shorten the wheelbase, etc. you won't notice a huge change in handling.
HeavyD99 and cameronspruill like this.
Krio is offline
