Team Associated B6.1 & B6.1D thread >
Like Tree794Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 02-28-2018, 09:14 AM
  #181
Sorry if this was discussed earlier. Looking at getting some Kashima bodies prior to my kit. Is the 6.1 using the standard the 23mm std. bodies in the front and the 31mm in the rear? Or is the rear the 27.5?
daveb is offline
Old 02-28-2018, 09:34 AM
  #182
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 167 (100%+)
B6.1D uses 31mm rear. B6.1 uses 27.5. Both use 23mm fronts.
windycityblues likes this.
Matt Trimmings is offline
Old 02-28-2018, 03:17 PM
  #183
The new spring options is what I'm most interested in.
Because AE are only offering one step softer than the B6.1D kit White for the V2's I'm hoping the V2 Whites end up equivalent to the V1 Green's.
In Australia we tend to run Green with the V1's. Whites come out rarely when the grip is high than usual.
chipa is offline
Old 02-28-2018, 09:46 PM
  #184
ray_munday's Avatar
Originally Posted by bobf24 View Post
that isn't answering my question at all, the front row on the laydown/layback doens't line up. So does that mean the standup that doesn't have that front row of holes will fit the old chassis? Just looking for clarification but thanks . . .
Im told that the standup transmission holes line up. However to use the new standup on the B6 you will need the B6.1 rear tower, rear camber link and rear bulkhead. Im told the B6 standup will fit the B6.1, I presume it also means that the B6.1 standup will fit the B6. Hope this clarifies.
Looking at the quoted rates of the rears as an example, the new green springs are rated softer than the old blacks. As soon as I get hold of the new springs I will do some back to back on our tracks and let you know.
Ray
jtodd57 likes this.
ray_munday is offline
Old 02-28-2018, 10:34 PM
  #185
Lazi's Avatar
im switching over from losi 22 4.0 and i like to know what rear hex should i get to run the tlr wheels? i have too many and i don't want to lose them
what is the ofset?
Lazi is offline
Old 03-01-2018, 04:03 AM
  #186
mes
what is the ofset?
Off-set should be identical, so as long as the thread on the stub axle is long enough, you should be fine. This is what I like about the Avid Satellite wheels, they fit on all the different platforms.
mes is offline
Old 03-01-2018, 10:58 AM
  #187
xyzracer's Avatar
Losi wheels are .75-1.00mm wider depending on the manufacturer
b1narych0ice likes this.
xyzracer is offline
Old 03-01-2018, 11:04 AM
  #188
Trader Rating: 28 (100%+)
working and being the same offset as the stock wheels isn't necessarily the same
bobf24 is offline
Old 03-01-2018, 11:52 AM
  #189
Super Moderator
So, word is you can only use a fan when running the slipper lockout. Thoughts?
Old 03-01-2018, 11:54 AM
  #190
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
#modmotor
Wildcat1971 is offline
Old 03-01-2018, 11:58 AM
  #191
AZJP's Avatar
Trader Rating: 21 (100%+)
Looking at the car, you could cut the end of the side rail off and mount it there.
AZJP is offline
Old 03-01-2018, 12:11 PM
  #192
Braxamus's Avatar
Any official word yet as to when this will be available for purchase? Also kind of wonder if one should not wait till the first batch is gone that way they can hopefully fix any small issues like there always seems to be on every new release.
Braxamus is offline
Old 03-01-2018, 01:29 PM
  #193
Super Moderator
I shouldn’t have to cut anything...
Old 03-01-2018, 01:31 PM
  #194
As a stock racer, I never needed a fan on either of my B6D's. My 22 4.0 on the other hand... saw motors go up, and almost lost one of my own, no matter the gearing.
Jason B is offline
Old 03-01-2018, 01:53 PM
  #195
A fan will only fit in the normal spot if you run the lockout. A fan will still fit in other places. If fan mounting position is the biggest worry, I think this is a winner.
jtodd57 likes this.
AE_Stig is offline
