Team Associated B6.1 & B6.1D thread >
Like Tree794Likes
    Hide Wikipost
Old 08-30-2018, 06:59 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday):
Print Wikipost
Old 07-24-2018, 08:59 AM
  #1561
Would you be able to do enough with setup and tire changes to still make the lay back transmission on the 6.1D work well on very low grip? Or is the standup transmission necessary to make the car handle well?
lowdoughracer is offline
Old 07-24-2018, 09:03 AM
  #1562
a1
Originally Posted by mrmatt47 View Post
Forgot to add that the track has varying conditions. Some times it gets loose and sometimes it is tight. Dont know why it just is. Same conditions and prep two days will result in different results
i believe that is just the nature of it . So many things to chase looking for a good tune but that makes it fun. we get a blue groove then they add water and its like driving on slick oil. Lol
a1 is offline
Old 07-24-2018, 09:12 AM
  #1563
Lone Drifter's Avatar
Any word on when the B6.2 is going to be announced.
eddosi and a1 like this.
Lone Drifter is offline
Old 07-24-2018, 09:46 AM
  #1564
lexusbest's Avatar
may not work best but you can make it work. The last race i had on very low grip with my b6 i finished 1st. Laydown and gear diff. Added some weight strips near mount C and D (20g and 10g). You can also check Ray Mundays setup guide.
if you are only racing on dirt i would get standup transmission
HeavyD99 likes this.
lexusbest is offline
Old 07-24-2018, 09:58 AM
  #1565
rvrslt1's Avatar
Trader Rating: 35 (100%+)
Does anyone have an update running without the waterfall?
rvrslt1 is offline
Old 07-24-2018, 10:06 AM
  #1566
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
Seems fine. I removed mine. No bending and still seems plenty stiff. A little more consistent and rear grip. IMO
rvrslt1 likes this.
Wildcat1971 is offline
Old 07-24-2018, 10:13 AM
  #1567
This is not TLR lol.
outoftouchrc is offline
Old 07-24-2018, 10:14 AM
  #1568
lexusbest's Avatar
2 weeks
Old 07-24-2018, 10:46 AM
  #1569
lbckevin's Avatar
Trader Rating: 96 (99%+)
Most of us at OCRC are not running the waterfall. I took out the top screw and it allows it to flex a little better for greater traction in the rear.
lbckevin is offline
Old 07-24-2018, 11:59 AM
  #1570
rvrslt1's Avatar
thanks for the info Kevin. I will give it a try.
rvrslt1 is offline
Old 07-24-2018, 12:09 PM
  #1571
What is the pivot position for the c/d pills on the tuning sheet and what does it effect? I know what anti squat, toe and roll center are just cant find anything on the pivot position.
brad532 is offline
Old 07-24-2018, 12:34 PM
  #1572
a1
Check pilla position calculator on this page. I believe what your asking affects roll centers. Move position around on spreadsheet and it willsay wether high or low roll center.
http://site.petitrc.com/setup/associated/SetupSheetsAssociatedRC10B6.html
a1 is offline
Old 07-25-2018, 07:38 AM
  #1573
5tone's Avatar
Hi mates,
from the beginning my transmission isn't completly free
i checked many things (diff height spacers, screw size, gearbox thightness ...)
i also switch the idler gear from my B6 (and the diff as well)
... the only way to get it completly free is to use the n4 diff height spacer
other than that there's a hard point and/or a too tight gear mesh
is it normal ? do i have to grind it to get it free with the n2 spacer ?
5tone is offline
Old 07-25-2018, 09:16 AM
  #1574
Originally Posted by 5tone View Post
Hi mates,
The 4 screws that hold the gear diff together rub the pill spacer... Check that.
bshack is offline
Old 07-25-2018, 09:39 AM
  #1575
Originally Posted by bobf24 View Post
I think half the problem people have with ball diffs is the "modern" recommended build procedure. I still build them the way it was recommended 20 years ago and a stock AE ball diff running on outdoor dirt will last me all summer and still be smooth at the end of the season. I ran a ball diff on indoor carpet with slick tires in buggy and stadium truck this winter and they would last me 3 or 4 race days and 3 or 4 practice days before they needed to be rebuilt. I personally hate the way a gear diff feels even on carpet.
Care to share you diff building procedure?
MrLean is offline
