How to cut an e-clip slot in shaft without a lathe? >
Old 02-09-2018, 11:45 PM
Default How to cut an e-clip slot in shaft without a lathe?
Hi All,
I'm trying to create several e-clip slots in a short metal rod. Its a rod that will be in a 2wd differential as the final output shaft.
At first i thought of putting the rod in a drill, then putting a cutting disc on a dremel, turning both on and letting them meet.
Then i thought that perhaps only the rod needs to be in the drill, and i can grip the dremel's cutting disc in a pair of vise-grip pliers and let it make contact with the spinning rod.
Has anyone tried this or know of any other cheap'n'easy ways (and also safe) to get this done? Thanks for listening!
exwhyzed is offline
Old 02-10-2018, 12:20 AM
Yeah that’s your best bet. Shaft in dremel and cutting disc in a vice. Safety googles would be a good idea.
Tom87 is offline
Old 02-10-2018, 06:48 AM
goehm's Avatar
Trader Rating: 45 (100%+)
Would it be easier to find an appropriate diameter hingepin that already has a slot in it, and just cut it down to size?
goehm is offline
Old 02-10-2018, 09:58 AM
platgof's Avatar
I have done the drill and dremel combo and it works . Just secure the drill, maybe just lean on it, but use some zip ties to regulate the speed. Then touch the dremel to it.
platgof is offline
Old 02-10-2018, 01:25 PM
dtr
dtr's Avatar
Originally Posted by exwhyzed View Post
Hi All,
You need to keep the cutting disc rotating, otherwise the shaft will quickly heat up the contact spot and destroy the disc.
dtr is offline
Old 02-11-2018, 01:23 PM
Trader Rating: 33 (97%+)
if it were me, I'd go the other direction and use a die set to cut threads and back with M3 lock nuts instead of e-clips, far easier all the way around
If you take some measurements, then chances are you can find some threaded arm pins from a compatible brand just as easy without having to mill your own parts either!
billdelong is offline
