Old 01-07-2018, 03:28 PM   #1
Default Traxxas rustler battery
Can I place a more powerful battery in the car without making changes
Ponato316 is offline   Reply With Quote
Old 01-07-2018, 03:39 PM   #2
What version of the rustler? What kind of battery you thinking?
Dave_S is offline   Reply With Quote
Old 01-07-2018, 04:02 PM   #3
Just the rtr brushed rustler not sure my battery is bad so I figured if I could id just upgrade was looking at a 11.1v
Old 01-07-2018, 06:55 PM   #4
You can go to 11.1v 3s if you have the velineon. If it's an xl-5 you can use a 2s but a 3s is too much
Edit:just saw the brushed part. You can go with a 2s 7.4v lipo but 11.1v is too much for the xl5 esc
Myprixxx is offline   Reply With Quote
Old 01-07-2018, 07:50 PM   #5
slick2500's Avatar
These should work great in the Rustler XL-5. GForce 25C 5000mAh 2S 7.4V Car LiPO | Value Hobby
ECX Ruckus 1/10 2wd * Traxxas Stampede XL-5 * Traxxas Summit 1/10 * Team Associated Apex * Team Associated RC10B2 * Arrma Outcast
slick2500 is offline   Reply With Quote
Old 01-08-2018, 11:38 AM   #6
It comes with a 8.4v nimh battery is the Lipo more powerful that it's not rated for as many volts
Old 01-08-2018, 02:27 PM   #7
Is this your first time using lipos? Fully charged 2s lipo is 8.4v. Lipos will hold more consistent power (than nimh) through out the run till the lipo cutoff shuts off power to the motor (do not have it out in the middle of the street before lipo cutoff hits). Make sure lipo cutoff is set on the esc before using a lipo. Also you need to monitor the temps of the motor or you will be burning them up. Longer run times more heat. If you want more speed you will have to use a bigger pinion. But again you have to monitor motor temps. 3s (11.1v) lipos are best used with brushless setups.
Igottabeme is online now   Reply With Quote
Old 01-08-2018, 05:48 PM   #8
Yeah it's my first time using any of this stuff got a rustler for my kid. And it was pretty fun so I got one to race him around
Old 01-12-2018, 12:05 AM   #9
SocalSnakeEyes's Avatar
Send a message via MSN to SocalSnakeEyes
For speed:
Easy/cheap speed you can go with a motor replacement. The 12Turn it comes with is weak. Has been sense 1994. This 17 turn from AE will go right in and the added low end power will make the truck more fun. https://www.amainhobbies.com/reedy-r...sc9626/p142482
Normally, the less turns the faster but, keep an eye on heat, both in the motor and the speed control.
Or, your truck is Brushless ready. If you want to spend the money for it. There are so many different ones out there that I will only tell you that the Traxxas one is what the truck was built for and that Castle is one of the more trusted and versatile.
https://www.amainhobbies.com/traxxas...a3350r/p146995
https://www.amainhobbies.com/540-com...s/c1949?fb=167
Getting speed out of batteries has to do with there "C" number. More the better. Run time is the mAh number. More the better. Take a look at this Traxxas page to see what XL-5 you have, What it can do and, what batteries from Traxxas fit. They offer kits to extend the size of the battery box if needed as well.
https://traxxas.com/products/models/...rd?t=batteries
No, I don't work for Traxxas. I just have a thing for them. I do hope this helps get you and your son up to speed.
Adding of random thoughts related to my ramblings on.
"Speed only counts if you make the next turn" Jessica King #22
http://www.rctech.net/g/album/8613420#
Snake Eyes Racing EST. 1994 R.I.P. SoCal Raceway 12-16-2007
SocalSnakeEyes is offline   Reply With Quote
Old 01-12-2018, 02:12 AM   #10
Of course you could replace the battery. Gens ace has battery special for Traxxas, just need to change its plug.
betty is offline   Reply With Quote
Buy / Sell BoardSlapper Canadian R/C Scene 11304 Today 08:10 PM
Traxxas Rustler XL-5 Battery upgrade aussieinkguy Electric Off-Road 9 03-10-2012 05:36 PM
