Old 12-09-2017, 01:15 AM   #1
Default Want to up grade my motor
I have the scbe ten 2.0 it the fuse 3800 I'm looking for something better I do run it in sand. It runs pretty hot and I'm running a nah 5000 50c and gearing would be great to thanks guys??
Scbe10 is offline   Reply With Quote
Old 12-09-2017, 01:52 AM   #2
castle mamba max
beansor2bacon is offline   Reply With Quote
Old 12-09-2017, 02:02 AM   #3
Might want to try getting a fan for the motor. That should help bring the temps down.
Losi Ten/810/SCTE Sumo Racing Motor Fan Kit
Problem with running in sand I bet you are full throttle through the whole pack. Running full throttle all the time is going to keep your motor running hot.
BaggedRanger is offline   Reply With Quote
Old 12-10-2017, 09:33 AM   #4
Trader Rating: 26 (96%+)
I would go with a 1/8 motor to increase efficiency to lower temps increase speed acceleration and run time... probably stay with sensorless to keep costs down and have fewer issues with sand. ValueHobby...GoolRc...Turnigy are some brands to shop around... any 3674 or 4074 can will do the trick... ideally 2000kv to 2600kv on 4S would be ideal.
billdelong is offline   Reply With Quote
Old 12-10-2017, 10:08 AM   #5
Trader Rating: 171 (100%+)
As I am not a big fan on castle esc's I do like their motors, and my favorite is the 3800kv one thinking castle # 1410 as I ran that motor in my scte with lots of batteries at a time, it seemed to run over 200 degrees and still was a monster in that heavy truck, seems to me the castle motors take the heat better, plus you can gear them up
We go to have fun, that is why we go
Grand Cities R/C Club member
Ecrt.5 on 4s pack= 82 mph
Ecrt.5 on 6s = broken parts
We stand for our flag!!!!
Troubles Dad is offline   Reply With Quote
Old 12-11-2017, 08:41 AM   #6
kevinatfms's Avatar
If it runs hot then add a fan or heat sink and re-gear to lower the temps. Sand running is extremely hard on an RC and getting the correct gear ratio is required to keep temps in check.
As for the motor, as stated above, an 1/8 scale motor and more voltage would be a good way to go faster. 2100-2400kv with ESC and 4s would make it scream.
Anderson Power Poles for life!
kevinatfms is offline   Reply With Quote
Old 12-11-2017, 11:46 AM   #7
What battery are you running? 2s or 3s?
The fuze 3800 motor gets hot. But it rips pretty good. It's a 550 can so it's a bit longer than the castle 3800. I have a ten-mt with the fuze 3800kv. The motor rips hard... even compared to my SCT with the castle 3800 in it. If you're looking for a 10th scale motor that will increase your trucks performance with the same kv I don't think you'll find one. If you're looking for a cooler options to keep temps down then the only way is to go 1/8th scale electronics IMO. I have put vents in the body, a fan on the motor, geared it down from a 16t mod 1 to a 14t mod 1, bought a tuner, changed connectors and that motor still gets hot.
If it's a basher I would go with the castle mamba x and 2650kv motor or mamba monster x(idk if it would fit) and 2650kv motor. This on 3s will be similar to the 3800 on 2s top speed wise but with way more trq and lower temps. On 4s it would be similar to the 3800kv on 3s but with way more trq and lower temps.
Zinergy is offline   Reply With Quote
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46486 11-21-2017 09:29 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Losi Strike CORR SCT liljohn1064 Electric Off-Road 1710 11-19-2010 01:05 AM
bearings in stock motors BJL Electric Off-Road 12 09-01-2005 10:01 PM
