TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree139Likes
Old 12-05-2017, 10:40 AM
  #76
RazorRC's Avatar
Hi Frank,
You mentioned in the unboxing video that it would be hard to update the topshaft to use a 4mm nut (5.5 nut driver) because of the existing parts (slipper plates, spur gears, etc.).
MIP has a version of the TLR topshaft that uses a 4mm nut. I think they get around this problem by trimming down the sides of the shaft so that the slipper plates will go over it. So it looks like an all aluminum version is possible at least:
At least for me personally, this is one of the things I'd like to see changed.
RazorRC is offline
Old 12-06-2017, 06:42 AM
  #77
kaistas's Avatar
Originally Posted by Frank Root
Yes, the bones will pop out when running mismatch diff height and hubs/axle height.
I'm having this problem now. I put in the +3 inserts on the transmission, as well as using the +3mm rear aluminum carriers, but the bones are running at the very edge of the gear diff cups. With the truck lifted up off the ground, I can actually slide them out with a minimal amount of effort. I haven't brought it to the track yet, but I'm fairly certain they will pop out on even small jumps.
Other than the carriers, the only other non-kit part I'm using is the gear diff. I'll check when I get home to see if the drive cups on the gear diff are different than what comes with the ball kit, as that was the only thing I can think of.
kaistas is offline
Old 12-06-2017, 07:19 AM
  #78
mes
The manual suggests different amounts of droop limiters depending on whether the shocks are mounted in front of the shock tower or behind it. I'll built my 22T 4.0 the same way, but can't check if this is a common issue. My kit has yet to arrive, be wrapped and unwrapped in about two and a half weeks.
mes is offline
Old 12-06-2017, 07:48 AM
  #79
kaistas's Avatar
I have my shock length set within .25mm of their recommendation for forward mounted rear shocks. I'm also using the recommended 2 degree anti-squat and 3 degree rear toe as I didn't see anything listed specifically for carpet/turf.
kaistas is offline
Old 12-06-2017, 09:42 AM
  #80
mes
Strange... Are there various drive shafts for the 22 truck platforms?
Edit: Were the right drive shafts (93.25 mm) included in your kit? There seems to be just enough material on the product pictures of the outdrives to make it work. Too much material on the outdrives and they might bind when the arms move upwards...
mes is offline
Old 12-06-2017, 09:58 AM
  #81
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I'm lost, I really don't know how this is happening to you.
Frank Root is offline
Old 12-06-2017, 11:12 AM
  #82
kaistas's Avatar
I'll check that tonight. I remember numbers printed on the shafts, but I couldn't tell you 100% what they were from memory.
I'll take some pics and post them as well.
kaistas is offline
Old 12-06-2017, 11:34 AM
  #83
Did you forget to flip the diff inserts when installing the +3 idler inserts and +3hubs?
jmitchell is offline
Old 12-06-2017, 12:21 PM
  #84
kaistas's Avatar
No. Well, I did at first, but the diff won't mesh with the idler at all when the idler is set at +3, so I noticed that pretty quickly.
kaistas is offline
Old 12-07-2017, 05:39 PM
  #85
Default Setup sheets
Are there any setups out there or is everyone going with the kit setup?
rbrownsr is offline
Old 12-07-2017, 05:47 PM
  #86
You could always look at the 22t 3.0 setups
faqcya is offline
Old 12-07-2017, 06:51 PM
  #87
kaistas's Avatar
The shafts do say 93.25mm.
Here's some pics. You can see the how close the rod is to the edge of the cup. This is at full extension of the shock. I was able to change the camber just a bit to give it more room, and now I can't manually pull the shafts out of the cup (but it's still reeeeaallly close).
And my rear springs are both still very, very close to the recommended 33.0mm for forward mounted rear shocks.
kaistas is offline
Old 12-07-2017, 06:53 PM
  #88
Could you just run some droop limiters
faqcya is offline
Old 12-07-2017, 08:02 PM
  #89
TLRacing
Frank Root's Avatar
Photos of the diff inserts and hubs?
Old 12-07-2017, 08:35 PM
  #90
kaistas's Avatar
Sorry for the image quality, it's a hard angle to get with a cell phone.
Also, apologies for the mess. I'm also working on my 22 buggy (in the background)
kaistas is offline
