TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree110Likes
Old 12-02-2017, 09:32 PM
  #61
R/C Tech Elite Member
CCristo's Avatar
Trader Rating: 56 (100%+)
Anyone have problems with the transmission not spinning free even with no screws? I've double checked that the inserts are seated all the way and are straight, but there is still a lot of drag.
CCristo is offline
Old 12-02-2017, 10:54 PM
  #62
wrightcs77's Avatar
Trader Rating: 549 (100%+)
I seemed to remember hearing of similar issues with the 3.0 and 4.0 SR.
wrightcs77 is offline
Old 12-03-2017, 06:09 AM
  #63
Make sure that inner slipper plate is not rubbing at gearbox opening.
Roken is offline
Old 12-03-2017, 07:42 AM
  #64
everything on mine when building was spinning free. Im using the RTR gear diff for CRC 2 carpet and still free. I don't worry about what some say is "notchy feeling" it breaks in. Still need to finish up electronics install and paint work then its track time.
freebird is offline
Old 12-04-2017, 08:08 AM
  #65
CCristo's Avatar
Thanks for the suggestions guys. Everything is seated correctly and the slipper plate is not rubbing on the case. At this point I'm going to assume the case is bad and will get a new once once they are in stock. It's just disappointing to run into these problems with a new kit
CCristo is offline
Old 12-04-2017, 08:20 AM
  #66
Trader Rating: 166 (100%+)
Welcome to the new TLR.....
jpcopeland1 is offline
Old 12-04-2017, 08:45 AM
  #67
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Did you install the tranny into the truck yet?
Frank Root is offline
Old 12-04-2017, 02:35 PM
  #68
Originally Posted by Frank Root View Post
Did you install the car into the truck yet?
I'd like to see pictures of this.
faqcya is offline
Old 12-04-2017, 03:19 PM
  #69
TLRacing
Frank Root's Avatar
Me too
Old 12-04-2017, 03:53 PM
  #70
CCristo's Avatar
Yes, the tranny is in the truck. I will say, it got marginally better when I bolted the shock tower on, but it's still not as free as I'd like
CCristo is offline
Old 12-04-2017, 04:41 PM
  #71
TLRacing
Frank Root's Avatar
Make sure the inserts and bearings are fully seated. Also, make sure the correct length screws are in each hole of the tranny on the bottom. If you run the 12mm screws into the holes design for 10mm screws, it'll push the plastic into the diff gear. Lastly, make sure not to overtighten the long tranny screw that goes through the chassis brace, tranny and motor place, it can pull the motor plate over and cause the case to deform and tighten the gear train.
Old 12-04-2017, 05:01 PM
  #72
Spork's Avatar
I’m having the same issue as CCristo. Which probably makes sense, since we bought our kits at the same place. Checked all the stuff you mention. Everything spins freely when I load all the gears into one half of the case. Attach the other half, and everything binds right up. Chris is a veteran at this, and a heck of a driver ... he builds/has built a LOT of kits, from all the manufacturers.
I’m hoping things loosen up after a couple battery packs.
Spork is offline
Old 12-04-2017, 07:26 PM
  #73
Frank quick question. Im setting up for carpet so I built the trans with the option included inserts for high grip. Now if the rear hubs are not installed, because Im waiting for them to come in, would there be an issue with drive shafts being short in the outdrives? Can you or should you do one of these mods and not use the other. Like trans on not carriers. I saw a post I think on FB where someone did the carriers and complained about the bones popping out of the drives. You mentioned to him to be sure he used the correct inserts in the trans.
freebird is offline
Old 12-05-2017, 08:42 AM
  #74
TLRacing
Frank Root's Avatar
Yes, the bones will pop out when running mismatch diff height and hubs/axle height.
Old 12-05-2017, 08:54 AM
  #75
mes
You could try adding some droop limiters to your rear shocks, 2 or 3 mm. Running with a truck at low ride height on carpet, droop should not be much of an issue.
mes is offline
