TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree139Likes
Old 06-23-2024, 11:24 AM
  #691
Default sway bar lower link pivot ball
TheDak, what did you use for the sway bar lower link pivot ball? Thanks
Getitn1 is offline
Old 06-27-2024, 12:08 PM
  #692
Hey.
If i want to use the Associated rear gullwing arms and the AVID 13mm shocks, what is your beginning stroke?
And did you use the normal AE 0mm shock ends, or +2 / +4 mm ?
Thanks a lot, Uli
UliTLR22T5.0 is offline
Old 06-27-2024, 12:11 PM
  #693
R/C Tech Elite Member
ChocoTaco73's Avatar
When I still had mine I used the T6.2 rear shafts and +4 shock ends to get the droop I wanted for clay. This was with the standard height VR tower, not the VR tower for buggy shocks.
ChocoTaco73 is offline
Old 06-27-2024, 02:21 PM
  #694
okay, thanks a lot.
I will use the shorter Vision Tower and buggy shocks.
Uli
Old 06-30-2024, 04:20 AM
  #695
Hey.
I have 2 other questions.
I drive the 22x-4 buggy, and I didn't know this setup point what to do for the 22 5.0 / 22t
the Kick Angle is in the Setup sheet with 20 / 25 / 30
the normal kickup from the chassis is 25 deg? And how can I change the kickup, is there 2 different angle shims?
I want to plan the 13mm Buggy setup with the vision towers.
Which kick shim did you prefer, 3mm, 2mm, 1mm or without?!?
what changes in driving behavior at 3mm / 2mm / 1mm / 0 mm?
Sorry for so many beginner questions, but for this I am reallys a newbie :-)
Thanks a lot, Uli
Old 07-07-2024, 04:59 PM
  #696
lbsnoopy's Avatar
Trader Rating: 6 (88%+)
Default Shock pistons
What’s everyone using for shock pistons on the 22T 4.0 , for dirt with the avid 13mm shock bodies ?
lbsnoopy is offline
Old 07-11-2024, 07:41 AM
  #697
And can somebody tell me if you need the front end mod with cuttet arms and blocks?
Isn´t it possible to run the original arms and 5deg blocks?
Thanks a lot , Uli
Old 07-11-2024, 08:07 AM
  #698
You can run the original arms and blocks w/o cutting if you run TLR offset wheels. If you run AE offset you'll need to do the front end mod otherwise it will be too wide.
UliTLR22T5.0 likes this.
Old 07-11-2024, 10:53 AM
  #699
okay, thanks.
I want to use the Jconcepts Mono JCO3354Y , so i think i have to do the cut mod .... ?!?
Old 07-11-2024, 11:04 AM
  #700
Yeah, those are AE offset, plus you'll need the SCT front axles since those won't work with the stock 22T 4.0 front axles.
Old 07-11-2024, 01:34 PM
  #701
SCRAFAN's Avatar
Trader Rating: 23 (100%+)
Front arms back in stock at my LHS, hopefully see more stuff coming.
SCRAFAN is online now
Old 07-11-2024, 01:54 PM
  #702
ChocoTaco73 , i want to use the Vision Racing axles with 5mm and 6mm hex
ChocoTaco73 likes this.
Old 07-12-2024, 07:40 AM
  #703
Hey.
I would like to install a stabi set at the front.
Unfortunately the Losi 22 5.0 stabilizer set does not fit.
Which wider stabilizers do you install at the front, and which rods and balls do you use on the front arms?
Thanks a lot, Uli
Old 07-13-2024, 02:08 PM
  #704
The TLR SCT sway bars will fit, the rest of the 22 5.0 hardware does the trick.
