TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree130Likes
Old 06-09-2023, 05:39 PM
  #661
R/C Tech Elite Member
ChocoTaco73's Avatar
Originally Posted by SCRAFAN
This may be on here but could not find it, are you guys running AE wheels with the frontend mod and the rear 22x4 VHA hubs? (all the way around) BTW that truck is bad ass.
I am:
ChocoTaco73 is offline
Old 06-09-2023, 06:59 PM
  #662
thedak's Avatar
Yep
Jcon - JCO3354Y
22SCT Axles in the front
22X-4 Rear Hubs with 6.0mm Hex
thedak is offline
Old 06-14-2023, 10:42 PM
  #663
thedak Would you mind sending over a setup sheet? Would love to finish up my TLR 22T 5.0 the same way. Do you prefer the VisionRC rear sway bar over the stock TLR buggy? Hope to tear it up in Houston with the new class they are starting on carpet.
thedak likes this.
Chpappa is offline
Old 06-15-2023, 01:40 PM
  #664
I've never run a rear sway bar on my 22T but I ave on my 22 5.0 and I wouldn't run the TLR sway bat setup. When mounted in front of the tower even the thickest sway bar would allow the rear end to lean over enough that I had to space up the wing because it leaned so much, especially in reducing radius turns after the straight. As soon as I switch to the Vision rear mount that stopped, it was so much better. With the higher center of gravity of the 22T I doubt the stock TLR sway bars would do much.
thedak likes this.
Old 06-15-2023, 07:12 PM
  #665
https://www.bigsquidrc.com/tlr-annou...or-the-22-5-0/
A longer chassis for the buggy looks like it would be a good place for converting the buggy into a stadium truck.
SCRAFAN and thedak like this.
Rcdad42 is offline
Old 06-16-2023, 09:58 AM
  #666
thedak's Avatar
Get the RCLyfe or Vision
File Type: pdf
Rcdad42 likes this.
thedak is offline
Old 06-18-2023, 10:25 AM
  #667
I’m looking for the part number for the 22T front sway bar links. I tried online manuals but couldn’t find it. Would appreciate if some could share the part number. Thanks.
shortcut3d is offline
Old 06-18-2023, 10:29 AM
  #668
SCRAFAN's Avatar
Trader Rating: 22 (100%+)
Anyone how close the longer buggy chassis is in length to the stock truck chassis?
SCRAFAN is offline
Old 08-11-2023, 06:53 AM
  #669
thedak's Avatar
So far so good. Love these Vision Trucks.
ChocoTaco73 likes this.
thedak is offline
Old 08-14-2023, 09:13 AM
  #670
FYI, Vision Racing will be making a new rear shock tower for the 22T to run buggy rear shocks, basically the same one Dakota Phend was using on his over the weekend at the ROAR Nats. Combine that with buggy front tower and shocks and you may have the hot ticket for carpet and high bite clay tracks.
Nosnarb likes this.
Old 01-06-2024, 08:18 PM
  #671
thedak's Avatar
13mm buggy set up is now on
shortcut3d likes this.
thedak is offline
Old 01-06-2024, 08:36 PM
  #672
It's a joke I need a front arm and can't find any for sale. All back ordered
Bcollins82, thedak and ThisIsRDG like this.
Ohiorccarpet is offline
Old 01-06-2024, 08:53 PM
  #673
thedak's Avatar
Is a pickle
thedak is offline
Old 01-07-2024, 09:56 AM
  #674
But I'm sure if you need Promoto X parts they are plentiful
petersen114, Bcollins82 and thedak like this.
Old 01-08-2024, 08:27 AM
  #675
This is exactly why I gave up on TLR.
MaX-D is offline
