TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck
#631
Good to know they use the same trans case! Easy diff access sounds nice
#632
Any links to setups for loose outdoor dirt? I tried searching on here but the search option will not work for me.
#633
R/C Tech Elite Member
Not much on the interwebs, this was the closest I could find on petitrc: https://site.petitrc.com/setup/losi/...RCCCS20180527/
#634
TY
#635
So does anybody know where I can find a 27g brass anti-squat block for the 22T 4.0?
#637
I agree with KINGZJ, get the 5.0 buggy C & D block with the C block in brass (22g).
About 4 months ago I searched everywhere for the 27g brass block, and finally settled for the 22g 4.0 brass block from the buggy. Later realized I could have purchased the 5.0 setup (with the brass C block) with more adjustability for less cost..
I did find the handling improvement with the 22g brass block worked well - settled the rear nicely and was much smoother to drive through the corners (also put the shocks in the rear mount position to help the rear weight bias.
#638
Will I need anything else besides the C & D blocks? Pills or hinge pins?
#639
You will need the 5.0 C&D blocks plus the adjustable pivot inserts (pills).
Brass c-block is TLR 334065
Aluminum C&D + pills is TLR 334062
Alternate is to buy only the brass C-block + aluminum D block (TLR 334066) + the pills (TLR 334063)
#640
Ok one more dumb question...does anyone still make a complete aluminum steering kit for this truck...if so who and where?
#641
I don't believe so, at least not one that drops right in without some work:
https://losiracing.blogspot.com/2019...ur-22t-40.html
#643
The factory guys are running Vision carbon chassis, truck arms and turnbuckles, and guess everything else is all buggy parts. That’s why someone asked on a pic of Dakotah’s why the body mounts looked like they were in different place.AE guys are doing same with their trucks. Tyler ran a true 4.0 against them at Clash of Champions this past weeeknd and he said it was like taking a knife to a gun fight. Rumor is AE is coming out with new truck but the “bruggy” parts are gonna be sold as an option kit.
#644
i would like to see how they have the front body mounted...the buggy towers make that a trick
#645
