TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck
#557
If ballcups are popping off, make sure you are using a fresh set and also make sure when the shocks are at full compression/extension that there's no strain on the ballcup (too much of an angle) and also same with front wheels left/right and shocks compressed/extended.
#559
They are not popping off rather breaking in half..
#560
so i was looking at the TLR website... how does the 22T 4.0 come with a ball diff? Why not a gear diff? Is a ball diff somehow better in a ST? though i dun c how...
#561
Most dirt setups use a ball diff, and high traction surfaces get a gear diff. The 22t is based upon the 22 4.0 dc kit, and not the carpet.
#563
I use Schumacher captured ball cups on my 5.0 and 22x-4. I use them on all the camber links. There is pros and cons. Obviously the ball cups don't pop off. So something else is going to give. If you crash more than a couple times a night, othose are not for you. You'll lose an arm or caster block or something more serious than a popped cup. Once you pop a cup, its useless.
But personally, I dont use TLR ballstuds or cups on either of my buggies. Im probably in the minority but I've not had good luck at all with tlr ball cups. Where I dont use the Schumacher cups, I use AE ballstuds and cups.
#564
In other segments, what motors are people running in their trucks for high bite clay?
#565
#566
used to have the same problem with Schumacher ball studs and the caps
I used to use the captive ball studs for the worst offenders which where the roll links. Remember you need the special spacer too.
however one assistance was adding a shock o ring onto the ball stud before putting the cap on. It prevents the leverage occurring too much. Works surprisingly well.
In addition - as we know this is a weak point - never pop them off. Only use the Allen key to undo the caps and if you do undo them, replace them straight away.
ball studs that stay put - xray 24/7.
#567
My buddy has the 4.0 and he loves it.
#568
#569
