TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree131Likes
Old 12-23-2019, 07:20 AM
  #481
I'm converting a 3.0 to a 4.0 and I ordered the shock shafts that are in the parts explosion part of the manual. It calls for part 233024 (3.5 x 48mm). But in the manual for the build instructions it calls for part 233024 (3.5 x 55mm). Which part do I need? And how do you get them since they have the same part number.
Kennybrook84 is offline
Old 01-01-2020, 04:36 PM
  #482
Default Gear diff
Will LOSA 2954 gear diff work in the 4.0 ?
ajcavanah is offline
Old 01-01-2020, 05:49 PM
  #483
Johnoly99's Avatar
it would but why not go with the new gear diff, the G2 gear diff. I have a few in all my 22 series. Hereís a link
https://www.horizonhobby.com/complet...22-p-tlr232088
Johnoly99 is offline
Old 01-01-2020, 08:19 PM
  #484
Old 01-04-2020, 08:43 PM
  #485
Hi guys. Bought a 4.0 during the sale. I’ve been out of TLR cars for awhile now. I’ll be running 13.5 on carpet, slick tires that get sauced. What can you recomend for the build? Any good carpet set ups? Should I get a gear diff? Any help would be appreciated.
SuperDaveNT is offline
Old 01-05-2020, 06:46 PM
  #486
Johnoly99's Avatar
Originally Posted by SuperDaveNT
Hi guys. Bought a 4.0 during the sale. Iíve been out of TLR cars for awhile now. Iíll be running 13.5 on carpet, slick tires that get sauced. What can you recomend for the build? Any good carpet set ups? Should I get a gear diff? Any help would be appreciated.
13.5 and carpet you NEED a gear diff for sure. The new G2 diff with the metal gears is what I run. Other than that start off with 37.5w oil in front and 32.5w in the rear and go from there. Ride height of around 20mm if itís a fast high traction sounds good
Old 01-14-2020, 07:52 PM
  #487
Iím looking at Frankís 11/2018 IOCC carpet setup and canít figure out this:
ĒGlue front sidewalls to top of outer pinsĒ
Does anyone know what this is about?
Iím baffled 😕
DJPod is offline
Old 01-14-2020, 08:16 PM
  #488
Iím baffled 😕
Figured it out... just happened to see this discussed on 22empire. Adding glue to the sidewalls of the tires allows the truck to slip some instead of flip when it starts to roll up on the side of the tire. Had no idea we were talking tires here. 😁
DJPod is offline
Old 01-16-2020, 11:16 AM
  #489
strodedawg's Avatar
Trader Rating: 85 (100%+)
where can i find a set up for carpet for this truck?
strodedawg is offline
Old 01-16-2020, 11:35 AM
  #490
rc10t4orange's Avatar
Trader Rating: 16 (100%+)
http://www.tlracing.com/ProdInfo/Fil...CC_11-2018.pdf
Frank Root's setup
rc10t4orange is offline
Old 01-16-2020, 11:52 AM
  #491
strodedawg's Avatar
Originally Posted by rc10t4orange
thank you
Old 01-17-2020, 08:31 AM
  #492
I recently purchased my nephew a 22S ST for Christmas. Truck seems really nice as a starter for him, but I have had an issues that I'm hoping for some help with.
. We have broken (2) lower front a-frames in the short amount of time running. Both times they have broke where the inner hinge pivot goes through. Is there a company that makes a set of aluminum or carbon lowers for these? Or are there other kits that have inprooved lowers that would convert to my kit?
Thanks in advance!
dracerbrian is offline
Old 01-26-2020, 10:06 AM
  #493
jbright33's Avatar
Trader Rating: 15 (100%+)
Ok opinions on gearing. I am gonna be running a small/ medium carpet high bite track using a trinity monster 10.5t motor whats the suggestions on pinnion and gear size?
jbright33 is offline
Old 01-28-2020, 09:13 AM
  #494
Jim85IROC's Avatar
Does anybody know of a wheel that has the same offset as the 22T 4.0 wheel, but with less thickness between the hex and the outer surface where the nut tightens to? I bought a set of TLR7003 wheels for my SC5M drag car build because I need to pull in the track width a bit, but there's so much material between the hex and where the wheel nut goes that I can't get any thread engagement on the axle shafts. The Team Associated wheels have a much thinner wall in this area.
Jim85IROC is offline
Old 01-29-2020, 07:43 AM
  #495
jbright33's Avatar
say hello to mr. Dremel with a stone bit..
