TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree136Likes
Old 03-08-2019, 05:06 AM
  #391
Originally Posted by czrlaker
Any help is appreciated the pin on the driveshaft sits too much on the edge of the out drive on one side. any idea why
What diff, diff inserts and hubs are you using? I had a similar issue when I ran the aluminum gear diff with the +3 setup. I ended up putting a 1mm spacer on the inside of the axle to help.
jmitchell is offline
Old 03-08-2019, 03:41 PM
  #392
RazorRC's Avatar
could just be the camera, but one arm looks like it angles way more than the other. That would cause it.
RazorRC is offline
Old 03-09-2019, 03:08 PM
  #393
czrlaker's Avatar
Trader Rating: 34 (100%+)
I am using the aluminum gear diff. There's got to be something wrong with this. Frank?
czrlaker is offline
Old 03-11-2019, 07:32 AM
  #394
I believe the outdrives on the aluminum gear diff are a little narrower than the ball diff. You either need to put a spacer on the axle to push it inward, or use longer dogbones.
Old 03-11-2019, 08:12 AM
  #395
czrlaker's Avatar
I used a 1mm spacer. Not a huge difference I also added more negative camber. I'll see how it handles. Do they make longer cva driveshafts than 93.25mm
czrlaker is offline
Old 03-11-2019, 09:57 AM
  #396
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yes, we make 94mm driveshafts.
Search Results: 94mm: Team Losi Racing
Frank Root is offline
Old 03-11-2019, 10:02 AM
  #397
czrlaker's Avatar
Nice. Thanks Frank
czrlaker is offline
Old 03-11-2019, 06:52 PM
  #398
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
Subscribed
thirtydaZe is offline
Old 03-15-2019, 01:01 PM
  #399
I'm looking to pick up a used 4.0 or perhaps a 3.0 to save some money. What is the big difference between the 3.0 and the 4.0, and how does the performance of each differ? I will be driving on a hard packed clay track Outdoors
MaX-D is offline
Old 03-18-2019, 09:18 AM
  #400
TLRacing
Frank Root's Avatar
Laydown is the biggest difference. A 3.0 might not be bad for the tracks you'll be running on.
Old 03-21-2019, 08:04 PM
  #401
Northernbob's Avatar
Default Brass anti squat
What's is the part number for the brass anti squat. My Google Fu that failed me. I ran through the whole thread and didn't see it. Thank you.
Northernbob is offline
Old 03-21-2019, 11:08 PM
  #402
try tlr334041 although I believe it's been discontinued
faqcya is offline
Old 03-22-2019, 02:27 AM
  #403
Bummer. Thank you.
Old 03-22-2019, 03:40 PM
  #404
RazorRC's Avatar
Bummer. Thank you.
I think the 5.0 block may be compatible. Not 100% sure.
Losi Chaser likes this.
RazorRC is offline
Old 03-24-2019, 01:51 PM
  #405
Team Pink's Avatar
Trader Rating: 20 (100%+)
The new 22g brass block released at the time of the 5.0 buggy will work just fine.
Team Pink is offline
