TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree136Likes
Old 11-19-2018, 09:07 AM
  #346
czrlaker's Avatar
Trader Rating: 34 (100%+)
Originally Posted by jmitchell
Just use a ton of shoegoe to keep the rear of the body and wing from breaking off. It will reinforce the joint between the two and also help reinforce the body from breaking.
I'll try that
czrlaker is offline
Old 11-23-2018, 03:03 PM
  #347
For a beginner, will the 22t be better suited for me or a t6.1 would be better? Not for racing, just for having fun on carpet off road track!!
inlinesick is offline
Old 11-23-2018, 08:28 PM
  #348
Are there a better front ball cups for the hockey style cups?
fordohio is offline
Old 11-24-2018, 05:16 AM
  #349
ollie 45's Avatar
Trader Rating: 29 (100%+)
Thinking about making the switch from AE, who has done it, pros vs cons t6 or 22t?
ollie 45 is online now
Old 11-24-2018, 10:53 AM
  #350
RazorRC's Avatar
I own both the 22T 4.0 and the T6.1.
ollie 45 likes this.
RazorRC is offline
Old 11-26-2018, 09:51 AM
  #351
Hey Frank.
Would you be so kind and post your and maybe Reno's setup from IOCC?
Did you flip the bell cranks and used the 234007 spindles, too?
Thanks!
M.Boos is offline
Old 11-26-2018, 01:24 PM
  #352
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by M.Boos
Hey Frank.
Thanks!
We will post the setup later this week, or next week.
Frank Root is offline
Old 11-27-2018, 12:09 AM
  #353
Thanks!
Do I need the rear sway bar from the 3.0 SCT or from the 4.0 Buggy?
Running laydown gear box...
Thanks!
M.Boos is offline
Old 11-29-2018, 09:01 AM
  #354
TLRacing
Frank Root's Avatar
Thanks!
Thanks!
4.0 buggy.
Old 12-04-2018, 11:44 PM
  #355
Looking at the latest carpet setup for the 4.0T...so there is no need to flip the bell cranks and the 234007 spindles?
M.Boos is offline
Old 12-05-2018, 09:28 AM
  #356
TLRacing
Frank Root's Avatar
The TLR234007 spindles won't fit on the 22T 4.0.
Old 12-06-2018, 11:50 AM
  #357
Trader Rating: 117 (100%+)
Default 22T 4.0 Body Cracking
I received the body with this truck I purchased. Is this pretty normal for it to crack in the rear end like this (both sides cracked the same)? I know, don't crash, but that's not going to stop happening. Is reinforcing that area the only choice to help prevent it from cracking? Does someone make a better body?
Thanks for any help.
slider3 is online now
Old 12-06-2018, 12:15 PM
  #358
rayzcar's Avatar
Trader Rating: 23 (100%+)
“Better” is too subjective to answer but I’ve had most of my 3.0/4.0 T bodies eventually crack in that area. Yes, you can reinforce (fiber mesh with shoe goo, gorilla tape, zipties and others) to get more use out of the body before you have to trash it but of course it will add weight, higher up and in the rear. Using without the wing might cause less damage but just will have to make sure it doesn’t negatively affect setup/driving for your track. Alternatively, can always cut off the back and go truggy style with a buggy wing and mount (re-purposed one of my broken 22T 4.0 bodies to use on my 1/10 truggy).
rayzcar is offline
Old 12-06-2018, 12:31 PM
  #359
Anyone have a decent carpet/turf setup they want to share?
As used in the Frank Root buggy setup, does it make sense to to the bellcrank flip and the 2.0 spindles? I'm a little hesitant to put the 2.0 spindles in because they have 4mm of trail and I've had issues with the front wheels rubbing the a-arm at/near full steering.
I have the same problem with the wheels rubbing the front arm at/near full steering...what did you do to prevent this ? Running trail 3mm and Ackermannarm #3.
M.Boos is offline
Old 12-07-2018, 05:31 AM
  #360
I run 3mm of trail, trimmed the a-arm where it rubs, as well as the inside of the wheel where it rubs. It clears good enough now.
jmitchell is offline
