TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree131Likes
Old 09-13-2018, 05:43 AM
  #316
Trader Rating: 380 (99%+)
Ready for the indoor season to start!
rbrownsr and MrLean like this.
jonski is offline
Old 09-23-2018, 12:20 PM
  #317
Who's running on carpet? Are you competitive with the other brands?
SuperDaveNT is offline
Old 10-04-2018, 05:09 PM
  #318
Default 22T 4.0 on carpet
I picked up a 22T 4.0 the other week from a friend. First time back in a stadium truck since my XXT-CR! I ran it last weekend and I was very happy with the performance of the truck. I think Iíll make a few tweaks for the next outing and Iím sure this truck be amazing. The first night as the track picked up grip the inside tire rear tire started picking up and by the main it was traction rolling. I should have stopped saucing the tires after practice and maybe make the springs a little stiffer for my driving style.
Nolt2005 is offline
Old 10-10-2018, 04:28 PM
  #319
Trader Rating: 115 (100%+)
Default What Extra Parts are Needed
Someone my have already ask this. Just picked up the 22T 4.0 and was wondering if there are any particular parts that are common to breaking that I should keep in the box?
Appreciate the feedback,
slider3 is offline
Old 10-10-2018, 05:37 PM
  #320
RazorRC's Avatar
Inserts on the front wheel spindles can break, that's about it. If ballcups keep popping off, look into replacing them with a fresh one.
RazorRC is offline
Old 10-11-2018, 07:58 AM
  #321
I've only broken front end parts on mine. Spindles, inserts and ball cups are the top parts I would have on hand. A-arms maybe, but I haven't had issues with mine.
Ultimately what you break will depend on how clean you drive. If you hit a lot to stuff, then maybe get a few more parts.
jmitchell is offline
Old 10-11-2018, 12:52 PM
  #322
mes
If you are going to run the planetary gear diff, make sure to shim the stub axles and/or use longer driveshafts, IIRC from the 22T 2.0.
mes is offline
Old 10-15-2018, 12:46 PM
  #323
Trader Rating: 28 (100%+)
Just wondering if anyone has tried different shock pistons for setup and what the difference is. Something like the 1.4 x3 hole pistons vs stock.
dbracn is offline
Old 10-16-2018, 04:17 PM
  #324
RazorRC's Avatar
My thoughts on the 22T 4.0 vs. the T6.1...
RazorRC is offline
Old 10-21-2018, 10:56 PM
  #325
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Default Jconcepts Finnisher body
Did some running with the Jconcepts Finnisher body for the 4.0T and I like this body a lot. Truck felt like it jumped better and did kinda just everything better. Also doesnít look too bad either. Part number 0367
Give it a try if youíre in the market for a new body.
Eli is offline
Old 10-25-2018, 12:13 AM
  #326
Can you convert a sct 3.0 to a stadium truck
TlrLosi210 is offline
Old 10-27-2018, 10:04 AM
  #327
Dirtryder219's Avatar
Trader Rating: 58 (100%+)
What is everybody doing for chassis protectors? Havenít found a 22T 4.0 specific one yet...
Dirtryder219 is offline
Old 10-28-2018, 01:15 PM
  #328
Jpdanger's Avatar
Trimbrite Bodyguard Clear
Dirtryder219 likes this.
Jpdanger is offline
Old 10-28-2018, 06:13 PM
  #329
EMcB's Avatar
s1racing makes them and will ship to you. I can't post a link but you can go to their website and get one.
EMcB is offline
Old 10-28-2018, 09:48 PM
  #330
Thx fellas
