TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree137Likes
Old 03-17-2018, 05:43 PM
  #241
corn_bread's Avatar
Trader Rating: 41 (100%+)
Wow this thread has totally died
corn_bread is offline
Old 03-19-2018, 08:16 AM
  #242
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I've been here... I just don't have a carpet setup
Frank Root is offline
Old 03-19-2018, 10:48 AM
  #243
losicorey's Avatar
Default Ballcups
Hey frank. Have you guys been working on the ballcup issue? Truck is money besides that
losicorey is offline
Old 03-19-2018, 11:08 AM
  #244
mes
Need a good black carpet setup. Track is technical most layouts
I only ran mine once on EOS carpet, and I was able to hunt down the buggies. JConcepts tires, HRC front and rear, high diff and hub carriers, brass below the servo, electronics, 80g below the battery. Racing Performer purple/black springs, 550 oil in the front shocks, planetary diff with 15,000 Yokomo oil, and IIRC a light to medium rear sway bar to tune in on-power steering. I think that's about it, sold the truck meanwhile due to a lack of time.
mes is offline
Old 03-19-2018, 11:19 AM
  #245
kaistas's Avatar
Do you have the TLR part #'s for the weights?
kaistas is offline
Old 03-19-2018, 11:21 AM
  #246
skrichter's Avatar
Looking to confirm KYO springs (which appears to be a common setup for dirt), will actually fit this truck with the shocks in the front (of the rear)? I tried to install the AE truck specific springs, and even with the zero offset cups, I could not get a 28mm ride height (with body off).
What are folks using for springs other than the stock/old school TLR truck front springs, and buggy/truck rear standard springs?
skrichter is offline
Old 03-19-2018, 01:47 PM
  #247
mes
TLR331028
I used the servo plate and one of the 25 g plates. The 80 g brass plate is a generic item bought on eBay a while ago, which has the footprint of a square pack/saddle packs.
mes is offline
Old 03-19-2018, 02:37 PM
  #248
RazorRC's Avatar
I'm running AE truck springs (54/72mm).
RazorRC is offline
Old 03-19-2018, 07:17 PM
  #249
skrichter's Avatar
I couldn't get the ride height anything close to 28mm, especially in the rear with the shocks forward.
Old 03-19-2018, 09:39 PM
  #250
RazorRC's Avatar
Well, mine is a 3.0 with a 4.0 rear end, but I'm at 27mm ride height. I don't have my truck handy, maybe post your setup.
RazorRC is offline
Old 03-20-2018, 08:30 AM
  #251
TLRacing
Frank Root's Avatar
Ride Height is easy with TLR Spring
You can cut a coil off the springs if you need to get a little lower.
flyinr2003 likes this.
Old 03-20-2018, 11:03 AM
  #252
skrichter's Avatar
Agreed Frank!
I just wanted to try some setup things with the KYO or AE springs.
Old 03-20-2018, 05:37 PM
  #253
flyinr2003's Avatar
Agreed Frank!
Steve blue and yellow tar springs should work good for you, just sayin.
flyinr2003 is offline
Old 03-21-2018, 06:22 AM
  #254
Trader Rating: 72 (100%+)
Default Ball cups popping off
First time out with new kit and popped off ballcups on 2 different runs. Not bad crashes either. What's the fix for this issue? Does Lunsford ballstuds help, different ball cups?? Thanks
BradL is offline
Old 03-21-2018, 07:32 AM
  #255
skrichter's Avatar
I used these HD ballcups, everywhere that doesn't need the angled cups.
https://www.horizonhobby.com/rod-end...t-22-4-tlr6017
