HB Racing D418 - 1/10 4WD Buggy >
Like Tree192Likes
Old 05-23-2019, 06:41 AM
  #421
mes
Originally Posted by 91junior View Post
I think it was mentioned here before. The lack of support set up wise on HB website is concerning. Has anyone done much racing with the D418 on low bite outdoor ? It’s a bit of a toss up between this and the YZ4 - SF
The car is definitely a winner on loose dirt, David Ronnefalk obliterated the competition at last year's Euros. You could try contacting him directly on facebook. Online support for all brands of Neidhard SA (HB Racing, Team Orion, Performa Racing) is hit or miss, I am afraid, but their products are amazing.
mes is offline
Old 06-02-2019, 05:34 PM
  #422
Anybody else breaking rear shock towers? I ran mine for the first time today and broke the tower within 5 minutes. Just curious if it was a freak thing or somewhat common.
fbrk8r is offline
Old 06-02-2019, 05:36 PM
  #423
Word is you can fill the outer holes with ca glue and carbon fiber dust . Then chop them off and sand smooth since they are never used anyway ...
carpetburner is offline
Old 06-04-2019, 06:54 PM
  #424
Trader Rating: 33 (100%+)
Nope this 1/10 4wd kit most durable that i have and 2nd x-b4.
raved007 is offline
Old 06-12-2019, 03:11 AM
  #425
The_Doctor's Avatar
Originally Posted by gticlay View Post
Will you post the picture you saw?
Hb
Also tower is forward and shocks mounted in t tower bolt holes
The_Doctor is offline
Old 06-12-2019, 04:14 AM
  #426
Custom front shock tower like ronnefalk uses. Much smoother steering and better landing.
VulvaS40T4 is offline
Old 06-12-2019, 01:08 PM
  #427
gticlay's Avatar
Trader Rating: 14 (100%+)
Sooooo, you are running a screw through the front, through the shock mounting aluminum piece, then the tower, then 3mm of spacer, then into the shock tower mount? Quite a bit less uptravel, no? Have a link to where you found this or the picture? For carpet or dirt? Thanks!!!!!
gticlay is offline
Old 06-13-2019, 09:52 AM
  #428
Its from my own d418.Yes shocks are attached to shock tower hole and 3mm spacer to line shocks on better angle.It has like 3mm more downtravel than normal inside shock position.
Old 06-15-2019, 06:16 AM
  #429
gticlay's Avatar
I understood it is of your car, but I was wondering if you saw Ronnefalk or someone else doing this - and where you might have found that picture. Thanks for sharing the idea, BTW.
gticlay is offline
Old 06-15-2019, 01:46 PM
  #430
http://site.petitrc.com/setup/hotbod...CRC2019012527/
Old 06-19-2019, 01:39 AM
  #431
Default 13.5
What hearing should I be aiming for?
i am running the exotek spool with a 68 spur
cheers
grahame is offline
Old 06-19-2019, 03:11 AM
  #432
mes
Gearing depends very much on the specific type of motor. Not all 13.5 motors are the same, cf. the label on the current generation of Tekin motors.
mes is offline
Old 06-19-2019, 02:40 PM
  #433
Most motors come with instructions that list gearing recommendations.... I would start there.
Sofa King is offline
Old 06-22-2019, 02:28 PM
  #434
gticlay's Avatar
Hi Vulva - thanks for sharing that front shock tower modification. However, after looking at your mod vs. the pictures of Ronnefalk's car - that's not what he did. You can see that your shocks are even with the bottom of the shock tower where it meets the plastic part of the tower where Ronnefalks is inward and upward (but dramatically different from the OEM holes). I wonder how we can replicate those locations to see how it feels?
Ronnefalk front shock location
gticlay is offline
Old 06-23-2019, 03:24 AM
  #435
We have to move front carbon shock tower part 3mm more towards front and drill new holes to that. It should be similar like my mod so front has more grip and softer feeling.
