HB Racing D418 - 1/10 4WD Buggy >
Like Tree156Likes
Old 04-26-2019, 09:19 AM
  #406
Originally Posted by texag84 View Post
I did a quick search but I couldn't find an explanation for the hinge pin mount options. I see on the setup sheets that the same degree of kickup can show up multiple times with the different combinations. Can someone explain why I would use two of the one dot carriers vs two of the three dot carriers? Both would get me 10 degrees of kickup correct?
Difference is roll center only but same kickup. More dots lower rollcenter and less dots higher roll center.
VulvaS40T4 is online now
Old 04-27-2019, 02:08 AM
  #407
Originally Posted by VulvaS40T4 View Post
Heres my fine tuned astroturf setup for D418. Easy to drive and fast.
thanks for this man how do you set the droop of 2 lines in your setup sheet?
Dixon
BD1541 is offline
Old 04-27-2019, 02:51 AM
  #408
Iím going to have to look into this at some point down the road, I love my D413, tougher than nails, this looks a little longer maybe and a little bit lower center of gravity.
Jamtwo88 is offline
Old 04-27-2019, 04:34 AM
  #409
Dixon
Like this.
http://www.rctech.net/forum/attachme...oop-adjust.jpg
Old 04-27-2019, 11:04 AM
  #410
thanks man
BD1541 is offline
Old 05-12-2019, 07:17 AM
  #411
Default Air Ration shock set up
Does anyone know what type of shock cap bladder option called ĎAir Rationí are ?
iLike2driveRc21 is offline
Old 05-12-2019, 07:55 AM
  #412
Trader Rating: 39 (100%+)
They are talking about emulsion shocks, air mixes with oil no bladders.
iLike2driveRc21 likes this.
GettinLapped is offline
Old 05-12-2019, 12:35 PM
  #413
mes
Wrong spelling, it should be aeration.
mes is offline
Old 05-18-2019, 07:19 PM
  #414
Anyone ran the D418 on low bite? Got a good set up ?
91junior is offline
Old 05-20-2019, 06:07 AM
  #415
[email protected];15299798]im have run mine on our dry and loose aussie tracks with 7/80/5 in diffs. 37.5wt front and 30wt rear and the car is awesome. One thing i found was the bladder setup with shocks had too much rebound. I cut the bladders and turned them into emulsion which is alot better. More settled off jumps and bumpy tracks[/QUOTE]
Do u have any pics of how the shock bladders look after u cut them?
Old 05-20-2019, 06:09 AM
  #416
Ok cool so if I remove bladders and re-build / bleed shocks in the same way as with the bladders it will work?
Old 05-20-2019, 06:26 AM
  #417
Default Outdoor Dirt/clay medium traction set up sheet
In search of some set up sheets for hb418 on a outdoor dirt/clay medium traction track.
i googled it and could not find any which is frustrating.
Feels like HB have forgotten about this little beast of a buggy and are leaving all us passionate drivers to figure it out for ourselves.
Besides this forum, (which is very informative and extremely helpful) thereís nothing out there.
The HB website contains nothing.
If if it wasnít for the high performance and two other locals who also have a HB418, I would find another brand that actually gives a crap about its customers by offering support to assist in getting the most out of our rc cars.
Old 05-20-2019, 07:01 AM
  #418
gticlay's Avatar
Trader Rating: 14 (100%+)
I'm just racing on carpet and astro right now but I have some friends racing on that so I'll shoot them a message and see if I can get you something.
gticlay is offline
Old 05-20-2019, 06:57 PM
  #419
Sorry for late response, you cut out the center part (billow) and place the rest in the cap. screw it tight and push shaft up to bleed out excess oil and tighten screw. I find I have to repeat this process 2-times on most shocks.
Old 05-23-2019, 02:05 AM
  #420
I think it was mentioned here before. The lack of support set up wise on HB website is concerning. Has anyone done much racing with the D418 on low bite outdoor ? Itís a bit of a toss up between this and the YZ4 - SF
91junior is offline
