HB Racing D418 - 1/10 4WD Buggy >
Like Tree156Likes
Old 03-27-2019, 10:19 PM
  #391
bump.
slasn_48 is offline
Old 03-27-2019, 10:42 PM
  #392
mes
Is it just me or are the updates that have been tested for a while trickling very slowly into production? The weekend before last I had the opportunity to watch a couple of D418s, and while Marcel Schneider took the win in mod with his HB car, it seemed to me that weight transfer was excessive. Using 2K oil in your front shocks to tame the car down just does not seem right... What happened to those suspension mounts David Ronnefalk used at various races? I am not feeling guilty to lean towards the B74, I must admit.
mes is offline
Old 03-29-2019, 06:05 PM
  #393
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I agree it seems they hold updates too long. 2w buggy has been 3 years... d418 was 5 years. Slipper clutch for the 4w forever... list goes on. We need options to be successful on the track. I have turned several people to try HB in my area just racing the 4w class. I do wish they had Pro driver in America again to show the cars true potential.
Jumbo_Jaque likes this.
Cameron Kellogg is offline
Old 04-01-2019, 11:52 AM
  #394
bighurt98's Avatar
Default Outdoor setups for D418.
Any good setups for medium grip tracks, little dusty, with good grove?
Some say base setup pretty good also.
bighurt98 is offline
Old 04-01-2019, 06:46 PM
  #395
I've used the base setup for medium-loose grip, and it's worked fairly well for me. The only changes I've made are with the diff weights and stiffer springs/oils. Went with 7/80/5 in the diffs (F/C/R) (recommended from another person in this forum), and that seemed to work well when grip is low. More steering and a bit smoother through corners off-power. Went with stiffer springs as I was bottoming out a lot with kit springs, and also needing to dial in quite a bit of pre-load to get the ride height set.
Jumbo_Jaque is offline
Old 04-03-2019, 11:57 AM
  #396
Originally Posted by VulvaS40T4 View Post
This is final good low grip indoor setup for d418. Cannot get it more better than this.
can you post your setup sheet for outdoor Astro? Thanks mate.
BD1541 is offline
Old 04-08-2019, 09:05 PM
  #397
Anyone cut the outside holes of your towers off so the have a less chance to break. I have seen the rear towers break and the front towers are so wide its only a matter if time. Most every set up I have seen no one uses the outter two holes on both towers. Recent picture of David's car looks like he has done this on the towers he is running.
Old 04-09-2019, 07:15 AM
  #398
Trader Rating: 32 (100%+)
I did cut front tower and left two holes and i flip rear shock towers
raved007 is offline
Old 04-09-2019, 08:46 AM
  #399
Had earlier Hobbywing G3 V10 6.5T motor in my D418 and it even on slippery tracks required 10degree boost timing to go fast enough. Now new 5.5t orion ultimate mod goes better even without boost. Cannot wait to test this motor on our outdoor astroturf track in next month.
So smooth and so much power. 23/70 gearing on 6.5t and 21/70 gearing on 5.5t both with slipper.
VulvaS40T4 is offline
Old 04-10-2019, 08:41 AM
  #400
Anyone notice David's car has a new longer aluminum block on the front of his car? Maybe a dot4 block? Anyone have the skills to make a batch of these? I can see how they would help on carpet.
Old 04-14-2019, 02:32 PM
  #401
gticlay's Avatar
Trader Rating: 14 (100%+)
Will you post the picture you saw?
Cameron Kellogg likes this.
gticlay is offline
Old 04-14-2019, 08:00 PM
  #402
Picture zoomed in to show the new front block. No telling when HB would release this, but I want a pair.
Old 04-15-2019, 03:21 PM
  #403
Default 13.5 modifications
Does anyone know if there are any plastic gears that fit in the diffs? I know HB has made them for the Pro 5 and TCXX, just unsure if they will fit.
avink007 is offline
Old 04-23-2019, 03:13 AM
  #404
Heres my fine tuned astroturf setup for D418. Easy to drive and fast.
Old 04-26-2019, 09:00 AM
  #405
Questions?? Hinge pin mounts
I did a quick search but I couldn't find an explanation for the hinge pin mount options. I see on the setup sheets that the same degree of kickup can show up multiple times with the different combinations. Can someone explain why I would use two of the one dot carriers vs two of the three dot carriers? Both would get me 10 degrees of kickup correct?
texag84 is offline
