HB Racing D418 - 1/10 4WD Buggy
#346
Now to just get it to go forward...haha. you guys flip the diffs around?
#347
[QUOTE=AJrollin;15391435]Just in case it's not totally obvious - I got caught out with this - you'll also need to replace the existing 22mm length screws for longer ones (the ones for the shock stand-offs) with the added thickness. I found some spare 2mm washers and stacked them together, looking forward to mounting the shocks forward. Then at the last minute, noticed there wasn't enough thread with the kit 22mm screws to get the lock-nut on fully. (sad trombone).
#349
What's the benefit of spacing the front tower?
#350
Front and rear diff
Hi regarding d418, just wondering if its still hard to remove front and rear diff like d413 removing a lot of screws . Has it been updated? Is maintenance easier this time?
#351
Exact same
#353
Hey guys - not sure how I did it, but I found that both of the steering posts have broken right at the base of them - the part on the actual post right above the hex. Not sure how it may have happened - I've had a few solid crashes, but for the most part, I've never noticed an issue. Then today, I was driving and noticed that I lost steering all of a sudden - it would just lazily steer to the point that I couldn't round corners anymore. I then discovered the broken steering posts after that while checking over the car.
Anyone else have this happen to them? I'd think that rather than both of them failing simultaneously, one probably broke and just overloaded the other one until it finally failed eventually. I'm getting new steering posts from my LHS tomorrow, but didn't know if there were any tips to prevent it from happening again (aside from not crashing - which if that's the case, I may just buy 2 sets tomorrow.)
Cheers.
Cheers.
#354
Do you have the correct length screws in the steering posts. The screws should go above that point.
#355
[QUOTE=Jumbo_Jaque;15401585]Hey guys - not sure how I did it, but I found that both of the steering posts have broken right at the base of them - the part on the actual post right above the hex. Not sure how it may have happened - I've had a few solid crashes, but for the most part, I've never noticed an issue. Then today, I was driving and noticed that I lost steering all of a sudden - it would just lazily steer to the point that I couldn't round corners anymore. I then discovered the broken steering posts after that while checking over the car.
Cheers.[/QUOTE
It happened to me but i put longer screws and it works. Or buy D413 top brace from schelle only 8 bucks and cut.
https://www.facebook.com/photo.php?f...&theater&ifg=1
Cheers.[/QUOTE
#358
Same here, broke one, when I took the post out the first thing I noticed was the screw is to short...longer screw fixes issue. Wondering if you were to drill a hole all the way through the post and then use a long bolt to go all the way through with a nut at the top, probably over thinking it but thought it was worth a mention.
#359
I just picked up a new set of steering posts. Anyone know what the orange washers are for (or were they for the D413)? https://hbracing.com/en/cars/spare-p...-post-2pcs-en/
Also, just tried fitting a 12mm screw to it, unmounted. With the screw in as far as it'll go, there's about a 3-4mm gap. Not sure that the chassis would fill in that gap, so I'm thinking that a 10mm screw would be the max length to use as the bottom screws. Still, that's 2mm more than what the kits starts with, so will give it a go.
On a side note, it was pretty funny when word got out in the pits that an HB broke. Had a few people come up to me just wanting to see it - like they couldn't believe it.
#360
