HB Racing D418 - 1/10 4WD Buggy
#331
I picked up the exotek spool. It came with a 69t spur. I've got a new 13.5 to run, can anyone who's played around with a similar combo comment on a pinion starting point.
also, the springs feel weak for prepped clay surface, I guess I'll have to bump up there as well.
#332
#333
I’m running 28 or 29/69 with a team powers 13.5 V3 motor. I’m running on damp clay on slicks with tons of traction and tried HB70 front springs and 40 rear, and that was better but wasn’t quite firm enough. I tried some AE yellow buggy fronts that are 4.3 in/lb and went to a 1.3mm front sway bar and this was much better. I still want to find something a little stiffer for the rear but I’m getting close.
#334
My motor has been in the low 100’s with a fan on it. I could probably gear it up a little but I also like how fast it takes off with the spool.
#335
Stock shocks have 2 yellow o-rings. Change those to Traxxas x-rings. Much smoother and cheap also and does not leak.
https://www.amainhobbies.com/traxxas...tra2362/p45156
anywhere to get just the blue x rings?
also this link is out is stock. If I search the part number I find some but the pictures of the ones I find with the same part number show a standard o ring. Not an X ring.
Ideas?
#336
Its always x-ring on those packages even pictures show o-rings. Its updatet like 2014 or something. Those are 3dollars pack
#338
I think the AE springs I have now will be good, I’m thinking next time I’ll get some stiffer springs for the rear and go back to the 1.2 front sway bar and see how that is. This is with AE 55wt in the front and 40 in the rear. But yeah for high traction you’ll need something stiffer than stock for sure.
#339
I think that’s a good place to start. I think maybe even an 80 spring like the yokomo purple. I’m running that plus the 50 out back but that’s on super high bite carpet. Are you running a lcg light shorty to save weight or?
#342
Reedy setup
Well, there’s pictures but no setup. That’s disappointing. Looks like a TON of toe in but maybe that’s just the picture.
Reedy D418 pictures
Reedy D418 pictures
#345
[QUOTE=raved007;15390732]I think washers are used for to be able to mount the stand off closer in. I have wanted to move the shocks further in on the top, may give this a try.
