SCOOP: New Tamiya Competition 4wd >
Old 02-01-2006, 04:29 AM
bender's Avatar
Default SCOOP: New Tamiya Competition 4wd
This car will be shown at the upcoming toy fair in Germany.
Only cad drawings ATM though I believe this was the car some had spotted being tested last year at the Japanese Nationals.
Attached Thumbnails SCOOP: New Tamiya Competition 4wd-newtamiya.jpg
bender is offline
Old 02-01-2006, 04:40 AM
csdspeed's Avatar
Looks promising! I hope it would be out sooner or later so that I can try one.
csdspeed is offline
Old 02-01-2006, 07:04 AM
What kind of drive train is it, belt or shaft. It looks like an off center shaft drive. If Tamiya makes a jump into compitition 4wd off road racing, they will be a tough force to beat! Just look how quickly they developed and dominate the electric touring car market.
Freem is offline
Old 02-01-2006, 08:34 AM
WisRacr1's Avatar
I know I love Tamiya!!! It would be awesome if it gets released soon!!!
I love my XX-4 WE but I'd get that Buggy right away!!!
WisRacr1 is offline
Old 02-01-2006, 09:21 AM
Tech Legend
Wild Cherry's Avatar
Is it me , or are those the old "Super Shot" chrome wheels from way back ?
Wild Cherry is offline
Old 02-01-2006, 10:08 AM
mtn bkr's Avatar
Trader Rating: 18 (100%+)
Hard to tell, but it looks like the steering servo might be located towards the back end of the car. There's a long tie-rod going from the back of the car towards the steering. Weird.
mtn bkr is offline
Old 02-01-2006, 10:10 AM
mtveten's Avatar
Trader Rating: 28 (100%+)
Correct me if I am wrong but I though the shaft designs went away from raised and offset shafts to alleviate torq steer a long time ago. I am sure that any Tamiya pro level car would use a more conventional layout or at least one they hadn't already progressed beyond.
Mark
mtveten is offline
Old 02-01-2006, 10:19 AM
Davidka's Avatar
Trader Rating: 78 (100%+)
The cad drawing is of a belt car. The motor is oriented in line with a spur gear pwependicular to the chassis. I wonder how well they will be able to route the belt around the battery. The belt will either travel in a raised tunnel under the chassis (ala' 1988 Schumacher Cat) or in a tunnel under the battery that will raise the battery off of the chassis deck, that would be a bad thing for the ol' CG.
Davidka is offline
Old 02-01-2006, 10:32 AM
Tech Legend
What belt ?
I see a drive shaft , seems just a redo on the SuperShot ...
Old 02-01-2006, 12:06 PM
I agree, its a shaft drive!! Look at how the shaft enters the transmission in the front. It reminds me of the TA01/02 touring cars tamiya had in the 90's.
Wouter.Z is offline
Old 02-01-2006, 12:27 PM
bender's Avatar
The car is shaft drive, with the shaft running just over the cells (like the Durango).
The cells are loaded into the car from underneath the chassis (like JRX-S).
The car is nothing like any previous Tamiya car, the overall design is based around a fairly narrow chassis (when testing they were using B4 bodies on the car) with very long suspension arms.
The wheels are a new design, see the attached pic. They have a new mini-pin tyre as well.
Attached Thumbnails SCOOP: New Tamiya Competition 4wd-header_53879.jpeg   SCOOP: New Tamiya Competition 4wd-header_53881.jpeg
bender is offline
Old 02-01-2006, 01:11 PM
Davidka's Avatar
It's not a shaft, it's a belt. The motor would be turned 45* to be inline with the shaft and the spur gear would be running cross wise to the direction of the shaft. You can clearly see the spur gear cover in the photo. Keep in mind, with the configuration in the pictures the power would have to make 90* turns at the layshaft that the spur gear turns and 90* turns again at the diffs and then turn another gear to drive the diffs so that the diffs can be low enough to drive the dogbones. So that's 4 90* turns in the drive train to drive a 3 gear transmission at each end of the car. If it's not a belt then there are some serious drive train issues to overcome before this thing becomes anything more than a CAD drawing.
Where did this drawing come from by the way?
Davidka is offline
Old 02-01-2006, 01:23 PM
I know what you mean but what is that shaft above the batterij then??? Its not a chassis stifner (its not a nitro car) and its not for the servo because its to big. AnD I dont see a belt or any room for a belt.
Wouter.Z is offline
Old 02-01-2006, 01:46 PM
Davidka's Avatar
The white line is a belt, not a shaft. This is a CAD drawing so the detail is poor. The narrower one is the steering rod from the rear mounted servo.
I bet this is not a "real" design. A lot of the parts look like they were lifted past Kyosho models.
Davidka is offline
Old 02-01-2006, 01:47 PM
bender's Avatar
I think you'd better get your eyes checked
The motor doesn't have to be inline with the shaft. Tamiya pioneered the shaft drive design with a laterally mounted motor position.
I did a very quick and rough sketch on how it could be doneand found that only 1 friction point is added, but the cars handing would be much better due to motor and battery position.
bender is offline
