Old 09-17-2006, 01:39 PM   #361
Exclamation
Hi all,
I just received my Df-03 yesterday. And i have one and just one big problem.
As soon as i have pre-assembled the rear diff, i just noticed the "diff nut", which micht be made of plastic -I donno- was not there !!!
Actually I need two of them, one For the rear one and one for the front one.
I got aluminium nuts to TIGHT the screw, but i Didn't have the plastic item, called "D5" on the instruction manual, to put the aluminum nut in it and then TIGHTEN the diff
I didn't have find any references for that. neither in the instruction manual or on the net. I'm so disappointed
Could someone help me please ? What can I do ?
Thanks !!!
nikko-kamikaze is offline   Reply With Quote
Old 09-18-2006, 09:37 AM   #362
larrio's Avatar
Originally Posted by nikko-kamikaze
Hi all,
Thanks !!!
The part D5 is on the D-parts tree located on p.25 of your instruction manual, part #51251 $5.75 Retail. It is on the same parts tree that contains the hubs.
The installation instruction for this part is on p.4, step 2 of your instruction manual.
The manual is also available for download www.tamiyausa.com
larrio is offline   Reply With Quote
Old 10-15-2006, 10:58 AM   #363
Lightbulb
Hi all,
I ordered the one-way, slipper and many replacement parts for my DF-03 one week ago
Presently, I would like to change my shocks .
I was thinking about the 3racing ones, or GPM ones (for B4) ... because it's not much pricey ...
But I have doubts What do you think about the quality of these schocks ? Are they strong built, reliable, efficient ?
If not, Which ones do you recommend to me ?
Many thanks for your help all
Sim
Old 10-15-2006, 12:18 PM   #364
dallasv8's Avatar
Talking shocks
id personally try to get the tamiya alloy shocks, way better quality than the gpm etc.
http://www.tamiyausa.com/product/ite...oduct-id=53926
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
dallasv8 is offline   Reply With Quote
Old 10-15-2006, 03:08 PM   #365
Ok I'll go for these shocks
Thanks for your help !
Old 10-15-2006, 07:53 PM   #366
ford_racing's Avatar
Send a message via MSN to ford_racing
+2 for the Tamiya shocks, they are definately worth the extra money
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 10-16-2006, 01:16 PM   #367
Lightbulb
Hi all again,
I haven't received the slipper and the one-way as well as the heat sink, but I somehow have a question ... Cannot wait
Can I use a "48" spur pignon with the Tamiya Slipper ? Hope I can ...
Because Tamiya spur is a "0.5 module" and i Suppose it's not the same than Generic "48" spur, which should be 0.6 module (i think)
Thanks by advance,
(Hope you understood my question but I don't speak english very well - it's an headache for me )
Old 10-16-2006, 10:58 PM   #368
dallasv8's Avatar
Talking boing boings
speaking of those tamiya shocks,anyone know wher to get them?i want to try a set on my B4 buggy,
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
Old 10-17-2006, 12:07 AM   #369
Hi all again,
Thanks by advance,
0.5 works out to be about 47 1/2 dp, it is very close to 48p but I have not tried it with the 48p pinions, as for a spur I tihnk you may be able to get them to work
ARC R11
Yokomo YRF001
AE B5m
Old 10-17-2006, 01:35 AM   #370
bender's Avatar
The only spurs that fit the Tamiya slipper are the Tamiya ones, due to both the layshaft diameter and the way the slipper pads are keyed into the spur gear.
You could run B4 spurs but you would need to ream out the spur hole to 5mm diameter, plus use B4 slipper pads.
I believe you could do the same with ZX5 Lazer spurs too.
I think if you get a few 0.5 pinions off ebay stores combined with the spur gears included in the kit then you have a decent ratio range.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 11-03-2006, 07:16 AM   #371
Hawk6's Avatar
Trader Rating: 50 (100%+)
I have a brand new still in shrink wrap Dark Impact for sale in the For Sale forum here if anyone is interested. Hopefully, this link works, if not, just search the thread:
http://rctech.net/forum/showthread.php?t=135418
I have one, and they are nice buggies, but decided not to build the second - will be focusing more on on-road stuff for a while.
Thanks.
Hawk6 is offline   Reply With Quote
Old 01-02-2007, 06:15 PM   #372
streetracer745's Avatar
Send a message via AIM to streetracer745
were can i get a slipper kit for the truck? and what are some good upgrades, other then shocks, that i should get?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-02-2007, 06:30 PM   #373
RCMits's Avatar
Trader Rating: 25 (100%+)
tamiya makes the slipper kit for the 4wd buggy (not truck).
thread back.
RCMits is offline   Reply With Quote
Old 01-03-2007, 08:00 AM   #374
RYAN BARNES's Avatar
OK, new to this thread, but very familiar with racing. 1/8 nitro and 2wd B4.
A couple questions for the guys whom have been running the Dark Impact, I just picked one up and plan to race it next saturday(indoor offroad), I have the carbon fiber shock towers, titanium turnbuckles and alloy steering shaft, all on the way. As for this whole slipper setup deal, I would like to run the 48p B4 setup since I own 2 B4's. What B4 parts do I need? Shaft, plates,pads, spring, nut, etc...?? And I have an extra set of B4 shocks, will they work? Do only the Tamiya wheels fit? Thanks in advance.
Maybe I need to copy/paste this question into the other thread.
RYAN BARNES is offline   Reply With Quote
Old 01-03-2007, 06:05 PM   #375
Shocks will fit, wheels do fit
I tihnk you will need to start out with the Tamiya slipper but
also, you can carefully ream a b4 spur using b4 pads if your handy with a reamer and have steady hands ;-)
ARC R11
Yokomo YRF001
AE B5m
THE SCOOP ON DROOP XRAY2 Electric On-Road 3 03-21-2008 03:34 PM
Scoop Hirosaka NRX-12 MrUnlimited Electric On-Road 13 02-17-2006 09:20 PM
Scoop: Carisma 1/18 MrUnlimited Electric On-Road 6 02-14-2006 11:23 PM
Need some ideas on fitting air scoop, Xrayskid Electric On-Road 0 01-06-2006 05:38 PM
Motor Cooling Scoop R40Victim Electric On-Road 14 02-20-2005 11:21 AM
