Old 07-07-2006, 08:01 AM   #331
strodedawg's Avatar
Trader Rating: 56 (100%+)
i have a new never ran built dark impact with some hop-ups for sale in the for sale forum
thanks
strodedawg is offline   Reply With Quote
Old 07-16-2006, 05:51 PM   #332
SpeedyDad's Avatar
Keeping the thread alive.
I just got back from vacation so my son and I will be heading back to SRS this week to race our 2wd stuff and get some more 4wd practice time.
Still waiting on the B4 shaft. Hopefully, it will be here soon.
Chris Krieg
X Factory SCX-60 chassis #00 & SCX-60CF prototype #1(both retired)
X Factory X-6, X-60CF (prototype #2), SCX-60CF
X Factory - www.xfactoryrc.com
Stickit1racing - www.stickit1racing.com
SpeedyDad is offline   Reply With Quote
Old 07-17-2006, 01:43 AM   #333
B4james's Avatar
I have tested the Tamiya slipper running B4 gear and pads and works perfect, I had a friend redrill the hole and all good.
I have heard a lot of people complain about the back end bouncing around which I was able to replicate in stock form as the supplied springs are rubbish. I have an old set of Kyosho gold shocks running softer springs with heavy oil which I put on and it fixed the problem straight away. Maybe kit shocks will work but they definately need a lot better springs on them.
B4james is offline   Reply With Quote
Old 07-17-2006, 03:16 AM   #334
the kit springs are a tad hard, but it it more the piston and oil in the shock that causes the 'bouncing', you need to go to the small piston to increase pack and create some damping to the unit.
DA_cookie_monst is offline   Reply With Quote
Old 07-17-2006, 04:25 AM   #335
bender's Avatar
I got my Tamiya heatsinks and slipper last week, but as yet I havent had a chance to try it out. Just need to find the ZX5 bits now and see how well it fits together.
I have a very busy 6 weeks period with touring cars atm so it may be a while before I get to run the DI again
I actually discovered a neat little trick when re-building the back of the car....
We all know that there isn't a lot of room for the motor to move, and whilst it's possible to elongate the motor holes to get it move forward a bit more, it also entails grinding away some of those strengthening ribs on the chassis.
Also, I've also noticed that with the curve of the chassis under the motor - the more you move the motor forward, the more it begins to rub heavily on the chassis at the bottom.
Anyway, what I did was to raise the rear gearbox by 1mm, just by putting 1mm shims where the screws under the rear gearbox go, and under the front part of the gearbox that bolts to the upper part of the chassis.
It doesn't effect the driveshaft angle very much (i made sure I tested that), but it does give enough clearance for the motor to slide more freely
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-17-2006, 09:40 PM   #336
SpeedyDad's Avatar
Woohoo!! I got my B4 slipper shaft from England today and my Tamiys slipper kit (I like to hedge my bets) from Japan. The Tamiya unit will be a backup, just in case.
After a quick trip to the LHS for AE slipper parts, I installed the B4 shaft tonight. It went together very well. You don't use the brass bushing on the output shaft and you do not use the Associated slipper spring nut. It uses a 3mm nut.
A very nice piece it is. I'll be out at SRS Wednesday to test it out.
Chris Krieg
Old 07-18-2006, 03:15 AM   #337
B4james's Avatar
I am wanting to upgrade the front driveshafts to universals, other than the genuine Tamyia DF-02 shafts what other makes will fit e.g. Square, Tobee or 3racing. I have seen some decently priced square racing and wanting to know if they fit
Old 07-18-2006, 04:08 AM   #338
Tobee do some.
The B4 slipper shaft was designed to work with the car, so no point having a 4-40locknut on there, so I opted to have RW machine a 3mm thread.
Old 07-18-2006, 08:18 AM   #339
SpeedyDad's Avatar
I agree with that. Why have 1 standard nut to keep track of in all the metrics. Makes sense.
Chris Krieg
Old 07-20-2006, 07:36 AM   #340
B4james's Avatar
I have finished building and painting, here's a couple of pics
SCOOP: New Tamiya Competition 4wd-dark-impact-2.jpg   SCOOP: New Tamiya Competition 4wd-dark-impact-1.jpg
Old 07-26-2006, 02:24 AM   #341
B4james's Avatar
has anyone tried or built the new adjustable DF03 shocks that have just been released by Tamiya?
Old 07-26-2006, 04:06 AM   #342
just going to build mine in a minute.
Old 07-26-2006, 04:39 AM   #343
Mannkenpis's Avatar
Send a message via MSN to Mannkenpis
Thumbs up
Different, nice job buddy ! If you have some white or colored wheels feel free to post it.
Mannkenpis is offline   Reply With Quote
Old 07-26-2006, 10:40 AM   #344
the new shocks, built them, they are super smooth.... and build up exactly like TRF shocks.
Old 07-26-2006, 08:33 PM   #345
B4james's Avatar
Thanks mannkenp, I have white wheels for it coming and also are about to paint up a body for TCS concourse. I did this one just for racing to be nice and bright.
THE SCOOP ON DROOP XRAY2 Electric On-Road 3 03-21-2008 03:34 PM
Scoop Hirosaka NRX-12 MrUnlimited Electric On-Road 13 02-17-2006 09:20 PM
Scoop: Carisma 1/18 MrUnlimited Electric On-Road 6 02-14-2006 11:23 PM
Need some ideas on fitting air scoop, Xrayskid Electric On-Road 0 01-06-2006 05:38 PM
Motor Cooling Scoop R40Victim Electric On-Road 14 02-20-2005 11:21 AM
