SCOOP: New Tamiya Competition 4wd >
Old 05-18-2006, 12:12 AM
  #226
No slipper clutch leaves the rear diff open for abuse. (aftermarket part in the process)
Ball Cups are not realy up to it (sure Tamiya do some TRF versions)
Front driveshafts (use DF02 Tamiya CVD's)
Inner hinge pin brace (GSStorm does some)
DA_cookie_monst is offline
Old 05-18-2006, 01:09 AM
  #227
tetsuo's Avatar
Thanks Cookie Monster for pointing out the weak points.
Tamiya have got the slipper clutch on the way (although at TCS I won't use it), Tamiya low friction adjusters - check, Tamiya DF-02 CVD's - check...
What's the Inner hinge pin brace?
tetsuo is offline
Old 05-18-2006, 03:13 AM
  #228
due to the mounts for the suspension on the rear being a gearbox integral part, a snag on the rear wheel could see a gearbox case gone, the brace goes between the two inner pins to stop them being ripped apart.
Old 05-18-2006, 11:55 AM
  #229
SpeedyDad's Avatar
Good. Would have been nice to include it with the kit.
SpeedyDad is offline
Old 05-18-2006, 01:27 PM
  #230
bender's Avatar
Looking forward to seeing pic of the DI hop-ups over the next few days from the Shizouka Show in Japan.... but in the meantime.....look at this:
Tamiya's TRF501X! Will they release it?
bender is offline
Old 05-18-2006, 01:40 PM
  #231
bender's Avatar
Pics of the DI hop-upd over at Jimmy's Oople site HERE
bender is offline
Old 05-18-2006, 07:37 PM
  #232
sim600's Avatar
Trader Rating: 15 (100%+)
Hi Da_cookie_monst,
You fit a GS Storm hinge pin brace onto the DI? Direct fit? Is it just a simple plate with 2 holes like what bender has on the front or an intricate design that I won't be able to hacksaw up?
sim600 is offline
Old 05-18-2006, 07:40 PM
  #233
sim600's Avatar
Da_cookie_monst,
How about the pinions and spurs and other gears? Not more than usual wear on them?
sim600 is offline
Old 05-18-2006, 11:50 PM
  #234
I think the spur and pinion are junk and it doesn't help them being a non-standard fitment, hence having a new layshaft to accept the B4 slipper assembly so I am back to 48dp and good quality spurs/pinions.
the brace is a simple plate, two holes like on Benders car.
Old 05-19-2006, 09:33 AM
  #235
Tommy Bergfeldt's Avatar
I found something interesting on a Shizuoka coverage site.
Looks like KM Concept is developing a Carbon Fiber conversion for the Dark Impact
LINK
Tommy Bergfeldt is offline
Old 05-19-2006, 11:48 AM
  #236
Racing4Evo's Avatar
hey guys, Tamiya is working on a 4wd buggy so it would seem.
More pics here:
Racing4Evo is offline
Old 05-20-2006, 01:48 PM
  #237
captain america's Avatar
LINK
I'm at a bit of a loss to explain why KMC chose to produce the carbon chassis with a saddle configuration. The battery is the single heaviest component that goes into the car. Surely the longitudinal battery layout Tamiya devised would yield better handling with its fully central position, would it not?
captain america is offline
Old 05-21-2006, 04:47 AM
  #238
fabolousRC's Avatar
WOOO HOOOO!!!
For those who say NAY to CF chassis, there is your answer right there eventhough it wasn't quite as major and quite "double" as I thought they would be (I myself don't know who KM Concept are). The steering servo placement is quite interesting and I don't know if that is going to work or not because the attack angle for the servo saver linkage would've been too close to the main shaft. That is like TB01 de ja vu all over again (with the steering linkage grinding onto the main shaft.
fabolousRC is offline
Old 05-21-2006, 12:38 PM
  #239
capellone24's Avatar
i really don' like it ..........i can't understand why KM has developed this CF chassis for the dark impact.....the original design is ignored.......i think that nobody has developed a similar cassis for a B4 buggy ....so i can't see why is necessary for the DF-03......hope that tamiya (and square,3racing...) will realease some plastic/graphite chassis for this buggy and some carbon fiber and alu stuff like pivot,bulkead and towers.....
bye
capellone24 is offline
Old 05-22-2006, 04:37 AM
  #240
bender's Avatar
bye
I agree, I also don't like it - having a cell layout like that completely goes against one of the main features of the original design \
You can bet that Tamiya will release a graphite tub, it's just a question of when
bender is offline
